How Do I Estimate the Number of Injected Holes in a Pulsed Laser Experiment?
  • Context: Graduate
  • Thread starter Thread starter pazmush
The discussion revolves around estimating the number of injected holes in a pulsed laser experiment involving a germanium sample. Participants are exploring curve fitting techniques using Origin software to analyze experimental data, while also seeking guidance on initial parameter setup and the impact of various experimental conditions.
  • Homework-related
  • One participant inquires about the approximate number of injected holes from a pulsed laser light, indicating a lack of clarity on how to determine this value.
  • Another participant asks for details regarding the experimental setup, including spot size, laser power, sample type, laser wavelength, pulse duration, and temperature, suggesting that these factors are critical for accurately estimating injected holes.
  • A participant expresses difficulty in fitting a curve to their data in Origin, questioning whether parameter initialization is necessary.
  • Further clarification is requested regarding the definition of the fitting function, including the names and number of parameters, as well as the dependent and independent variables.
  • A participant shares their fitting function and initial parameter values, proposing that the total number of holes injected (h) might be around 1E8, while providing values for other parameters (a, b, c, d).
  • Another participant offers advice on fitting procedures in Origin, mentioning the importance of compiling user-defined functions and checking for potential errors related to decimal separators.
  • One participant requests assistance with fitting their data, indicating a desire for collaborative problem-solving.
Participants generally agree on the complexity of estimating injected holes and the importance of experimental parameters, but there is no consensus on the specific values or methods for fitting the data. The discussion remains unresolved regarding the effectiveness of the fitting process and the accuracy of the proposed initial parameters.
Limitations include potential dependencies on the definitions of parameters and the specific experimental conditions, which have not been fully detailed. The discussion also highlights unresolved issues related to fitting procedures in Origin software.
pazmush
I've just completed an experiment using a laser to excite electons and hole in a germanium sample, and i want to fit a curve to some of the dat I've collected n origin, but i need to set up some initial parameters and i don't know how to work out what the original number of injected holes.
So does anyone know, round about, the number of injected holes from a pulsed laser light?
Or how to do my fit in origin
f(x) = h*(exp(-a*x))*(1/((b*(x+(1/a)))^0.5))*(exp((-(c-(d*x))^2)/(b*(x+(1/a)))))
thanks
Well, how large was your spot size and your laser power? Was it bulk germanium or some nanostructure (are you looking for free electrons and holes or excitons)? What was your exciting laser wavelength? What was the pulse duration? Which temperature did you work at? This question is really not trivial.
I assume you have a newer version of Origin (7 or newer).
Plot your data points and go to analysis->nonlinear curve fit->advanced fitting tool. Check, whether the function you need is one of the ones included or choose function->new and define your own function.
ok thanks I've done that but id doesn't seem to fit a curve to my data, it just outputss a curve with the values of my initial parameters, do i have to do some parameter initialization?
Ok. Did you define your own function?
If so, could you just paste in, how your function is defined exactly, what the names of your parameters are, how many parameters you use and what your dependent and independent variables are?
thanks for this
y = h*(exp(-a*x))*(1/((3.14*b*(x+(1/a)))^0.5))*(exp((-(c-(d*x))^2)/(b*(x+(1/a)))))
independent = x
independent = y
parameters = h,a,b,c,d
h is the the total number of holes injected? = 1E8?
a = 1000?
b = 0.012?
c = 0.005?
d = 75?
i'm using origin 8 by the way
Looks ok so far. I usually use Origin 7.5, but I hope user defined fitting is still the same.
So how do you try to fit? You switch to Action->Fit, choose a dataset, check vary vor all parameters and click 1 iteration (or 100)?
Sometimes it is sensible in Origin 7.5 to use "edit function in code builder" directly after defining the function and to save and most important compile it there. The user defined fitting sometimes won't work, if you don't compile it this way. Other possible error sources are using "." as the decimal seperator, but having "," set as the predefined decimal seperator or just using the chi sqr button by accident.
can i give you some data and you see if you can fit it please?
