How does the 'atmosphere' of the sun affect ligth from stars passing behind it.
The discussion centers around the effects of the sun's atmosphere, or lack thereof, on the bending of light from stars that pass behind the sun. Participants explore the implications of this bending in the context of Einstein's theory of relativity, particularly during solar eclipses. The conversation touches on theoretical and conceptual aspects, as well as the potential for various atmospheric effects on light propagation.
  • Some participants propose that the sun has an atmosphere composed of gases like hydrogen and helium, which could potentially bend light.
  • Others argue that the bending of light is primarily due to the sun's mass affecting space-time, as described by Einstein's general theory of relativity.
  • A participant questions the impact of the sun's mass ejections and coronal mass ejections (CMEs) on light bending, suggesting that even a transient atmosphere could have effects.
  • One participant mentions the density of the sun's atmosphere as being very low, implying that any optical effects on light would be negligible.
  • Another point raised is the concept of achromatic aberration, which could theoretically occur if light were refracted through a medium, but its relevance in this context is debated.
  • Some participants express confusion about whether the sun has an atmosphere, with differing opinions on the definition and implications of a stellar atmosphere.
  • A later reply discusses the index of refraction of the atmosphere, suggesting that while achromatic aberration exists, it may not be pronounced enough to be noticeable during events like sundown.
Participants do not reach a consensus on whether the sun has an atmosphere that affects light bending. There are competing views regarding the significance of the sun's mass versus its gaseous emissions, and the discussion remains unresolved on the implications for Einstein's relativity experiments.
Participants note that the density of the sun's atmosphere is very low, and the effects of any gas present may be minimal. There are also unresolved questions about the nature of light bending and the potential for various atmospheric effects to influence observations during solar eclipses.
BernieM
When the sun goes down over the horizon, we can still see the sun because the light of the sun is bent by our atmosphere. I would imagine that if one were outside of our atmosphere on the far side of Earth away from the sun, yet in a path in line with that light they would also see the sun (even though the sun were technically blocked from their view in a straight geometric line), due to this lensing effect of our atmosphere. Although the sun has no 'atmosphere' exactly, there is still a lot of mass streaming out from it such as hydrogen and helium, and so therefore doesn't it have some optical bending properties? My question here is this: If the sun is to be considered having an 'atmosphere' in any sense that can bend light, how does this affect the results that 'proved' einstein's relativity experiment where light from stars passing behind the sun during an eclipse 'emerged' early from behind the sun? Do the results need to be adjusted for solar atmospheric effects of any such effect if there are any?
Astronomy news on Phys.org
No, there is certaintly no atmosphere in the sun. I think you misunderstood Einsteins theory of realitivity. What cuases the starlight to bend is the sun's huge mass that bends space-time on which the starlight is traveling through. This cuases the light to bend relative to the sun's mass bending space-time. Read Einsteins general theory of relativity for further information on this specific topic to fully answer your question.
ugh .. I am fully aware of the gravitational effect of the sun bending light ... but I guess you did not answer my question ... since there IS mass ... a gas such as hydrogen ... WHAT EFFECT IF ANY does it have on bending of light around the sun? CME's ? matter streaming out from coronal holes? Maybe you should check out nasa's site and then come back and tell me that there is no 'atmosphere' ... or at least one that would have absolutely NO effect on light passing the sun ... a transient atmosphere is none the less still an atmosphere ... is it not?
http://www.spaceweather.com/
The link you posted says that the density of the "atmosphere" of the sun is 1.3 protons/cm^3
That is an incredibly thin atmosphere and I would assume any effect is has on light is negligible since it would interact with only a very tiny fraction of any incoming light. I would also assume it doesn't extend very far past the "surface" of the sun, because of the huge gravity the sun produces.
Another factor to take into account is achromatic aberration. When light is bent by refraction caused by a medium, different frequencies of light refract a different amount. This would cause a rainbow fringe around the image of the star who's light is bent. Gravitational lensing however, bends all frequencies equally. So any bending caused by the light passing through the Sun's atmosphere would be noticeable by its achromatic aberration.
The 'thinness' of the sun's atmosphere would depend on a lot of factors, such as how much turbulent activity there is on the sun kicking mass off the surface, also the sun has a much larger diameter and although this atmosphere is thin, there is a lot farther to travel through it.
The 1.3 protons/cm^3 is the density of the solar wind headed to the Earth from the sun and NOT the density of our sun's atmosphere. That was just the amount of mass in space headed to the Earth in the solar wind (on that particular day).
As for achromatic abberation, i think this might apply to solid materials as lenses. I watch the sun go down over the ocean and when the bottom of the sun appears to touch the horizon, the top of the sun in reality has already gone behind the horizon; and if i put sunlight through a prism i see the rainbow ... achromatic abberation ... however i don't see this happen at sundown so I guess achromatic abberation does not apply if you are 'in' the lens, and since i have not viewed the sun after it has passed through the atmosphere and back out I really don't know if it experiences achromatic abberation after passing through our atmosphere and then back out into space. Does anyone else know about this? But if this WERE the case, has anyone actually looked at the plates during solar eclipse proving einstein's theory and analyzed them to determine if there were any signs of achromatic abberation present?
Don't get me wrong here. I do not suggest that the theory of relativity is wrong. I simply want to know if there are other factors in play in the proof that could slightly 'skew' the results. The physics of a star are complex, for example recent observations where mass falls back to the sun ...
http://www.spaceweather.com/archive.php?month=09&day=29&year=2008&view=view
Read the article about 'Great Prominence' and there you will find the following statement ... "No one understands why the top of the prominence cascades down as fast as it does; the 'magnetic diffusion coefficient' of the medium shouldn't allow it. At the same time, swirls and vortices indicate an exquisite degree of magnetic control so far impossible to duplicate in Earth laboratories. How does the sun do these things? It's a beautiful mystery."
The same or other forces at work around or on the sun could possibly account for other phenomena. What I am trying to point out here is that there may be many effects around a star that could to some degree or another affect passing light that are not yet fully understood.
Ok ummm guys! Iam completely lost here. The sun has an atmosphere?!
The reason you don't notice the achromatic aberration during sundown is due to the fact that the index of refraction for the atmosphere is only 1.00029 (compared to the 1.5 for the glass prism). It's there, its just not pronounced enough to notice with the naked eye.
So what is the refraction of the sun's 'atmosphere' ?
Add another fifteen or twenty zeros to Janus' number.
Found this... " Light refraction by the Sun's atmosphere is calculated. As detected from the Earth, the refraction can deflect a light ray emitted from the Sun's limb by 13'' or a starlight ray grazing the solar limb by 26'' , an effect 15 times larger than the gravitational deflection."
http://www.springerlink.com/content/etwum62yqqhx8e6d/
It think it would also be difficult to talk NASA into pointing the Hubble anywhere near the sun.
Well, I don't know why we need to aim the Hubble at the sun ...
But now my question is this ... considering the effect of the sun's atmosphere on light of a star passing past the sun and being bent toward earth, shouldn't the results of the proof of gravitational bending of light be adjusted and recalculated? It seems to me that the effect of mass bending space-time may be diminished considerably.
The thing is that even during a total eclipse stars very near the Sun can not be seen because of the brightness of the chromosphere and corona. So to make observations of shifted positions of stars, you have to pick stars far enough from the Sun that their light does not pass through a significant thickness of the Sun's atmosphere to cause refraction.
Does anyone have a link to the actual experimental data and proofs?
The stars WERE measured for deflection after their light passed THROUGH the sun's atmosphere.
After the eclipse, Eddington himself carefully measured the positions of the stars that appeared near the Sun’s eclipsed image, on the photographic plates exposed at both Sobral and Principe. He then compared them with reference positions taken previously when the Hyades were visible in the night sky. The measurements had to be incredibly accurate, not only because the expected deflections were small. The images of the stars were also quite blurred, because of problems with the telescopes and because they were seen through the light of the Sun’s glowing atmosphere, the solar corona.
The entire article is here:
http://www.firstscience.com/home/articles/big-theories/eclipse-that-changed-the-universe-einstein-s-theory-of-relativity-page-3-1_1214.html
Well, as far as I see it, the sun does have an atmosphere, the effect of the solar atmosphere on light passing through it does bend the rays of light from stars behind the sun as it passes, this effect is 15 times more than gravitational effects and the proof did not take this effect into account, and I do not believe Eddington at that time would have had sufficient knowledge of the sun's atmosphere to know how far away from the sun a star should be so that solar atmospheric phenomena would not influence the results.
http://relativity.livingreviews.org/Articles/lrr-2006-3/" is, or should be, among the first places you go for things like this.
And in section 3.4.1, among other "actual experimental data and proofs", we read (emphasis added):
In recent years, transcontinental and intercontinental VLBI observations of quasars and radio galaxies have been made primarily to monitor the Earth’s rotation (“VLBI” in Figure 5). These measurements are sensitive to the deflection of light over almost the entire celestial sphere (at 90°from the Sun, the deflection is still 4 milliarcseconds).
Good resource, thanks for the link.
That's an interesting paper!
To avoid misunderstanding, the 13'' value is for zero distance from the Sun ("at the base of photosphere"). The paper clarifies:
"Although the refractive deflection is 15 times larger than the gravitational deflection of 1.75'' at the Sun’s limb, the former quickly becomes insignificant, in comparison to the latter, beyond r/rs > 1.0007 (Figure 3)."
PS. The practical consequence of this: if stars were measured too "close" to the surface of the Sun for verification of GR, this would result in a very poor reproducibility. And if the observed effect were only that of the atmosphere (negating GR), then anything from zero to several times the predicted effect would be measured.
the influence is there, and is not zero, so though it diminishes from distance, what non-zero impact on the observations did it play and how does that influence the calculations that were done in the past. In other words how much error did it introduce.
Additionally, according to Carroll & Ostlie (and some other sources that I couldn't name off hte top of my head), the original Eddington experiment was determined to be hogwash, although the results fit with GR. It doesn't matter really, hundreds (maybe thousands, I don't know) of experiments have been done to verify the theory. If you're going down the path of questioning GR, you might want to consider that.
Really not questioning GR. But other experiments may encounter similar effects, i.e., Dark Matter 'atmosphere' that could skew the results. I think if any the effect is tiny, however it is always best to get as accurate results as possible, which may require a slight adjustment in cases where this kind of effect may be present or later discovered.
  • · Replies 41 ·
10K
  • · Replies 25 ·
10K
  • · Replies 21 ·
