What Does it Mean When Things MUST Go Wrong?
  • Thread starter Thread starter Imparcticle
The discussion revolves around the implications of the multiverse theory, particularly in relation to personal experiences and outcomes, such as academic performance. Participants explore the philosophical and mathematical challenges posed by the existence of parallel universes and how these might affect notions of identity and determinism.
  • Some participants propose that in a multiverse, all possible outcomes occur in parallel universes, leading to questions about the significance of events in one's own universe.
  • Others argue that even if multiverses exist, the outcomes in those universes do not affect one's current reality, suggesting a disconnect between selves across universes.
  • A mathematical challenge is raised regarding the infinite nature of universes created by each moment's possibilities, questioning how such an infinite set can be managed or understood.
  • Some participants express uncertainty about whether the existence of a probability in another universe necessitates that the same outcome must occur in this universe, hinting at a deterministic view.
  • There is a discussion about the nature of identity, with some suggesting that consciousness delineates personal identity, separating individuals from their multiverse copies.
  • One participant references external sources, such as a BBC documentary, to question how multiverse theories relate to unifying theories in physics, like m-theory.
Participants express a range of views, with no clear consensus on the implications of multiverse theory for personal identity or the mathematical challenges it presents. The discussion remains unresolved regarding the connection between outcomes in different universes and their relevance to individual experiences.
Limitations include the lack of clarity on how multiverse theories can be reconciled with established physical theories, as well as the unresolved mathematical implications of infinite universes.
Imparcticle
Things MUST go "wrong"
According to the multiuniverse theory, all the probablities that occur in life occur in other parallel universes. Now, there is a possibility that I will either get an A or and F on a test. An F by my standards is bad. An A on the contrary is good. Both events (where I get an A or an F) occur in parallel universes. In this universe, I get an A, in a parallel universe I get an F.
Say I received an F in this universe. The only comfort I would have is that in a parallel universe, I would have an A and in another I'd have a B.
Now let us consider the occurrence where I receive an A. I would know that in a parallel universe, I would have an F.
So IOW, does it matter what happens at all? In another parallel universe (if things are not "perfect" for you) things would be perfect or if things are perfect for you, there would be an alternate universe where things are not perfect for you.
I feel I am heading in the direction of determinsm.
I would like input on my ideas and corrections in if any.
thanks.
a quick reply (hopefully not too quick)...
What would be the reaction of a professor if it was explained that all was copasetic because your assignment was being turned in right that very moment, in a parallel universe? :biggrin:
In practical terms you are in this universe. The others will take care of themselves, no need for you to always receive the short stick.
Even if we assume that multiverses exist as you have described them, you have have to ask yourself to what extent you are connected to your other 'selves.' If a multiverse copy of yourself gets an A, does that have any bearing on you in this universe? I think not. It would be silly to not care what grades you get because you know that someone else in your class will get an A, and it seems equally as silly (if not more so) to not care what grades you get because someone else in some other universe will get an A.
This theory seems to run into a bit of a mathematical problem. Let's say intially you have only one universe, and one moment passes in that universe. According to this theory, you have then created an infinity of universes in which every possible outcome of that moment (there are infinite possibilities) is played out. In the following moment, each of those universes would then need to undergo the same multiplication. But how can this be? You can't perform a mathematical operation on each number in an infinite set because you will never be able to finish (you can never reach the end of "infinity"). Does anyone know of a way to overcome this difficulty?
My point is, I will get an A and an F. In Universe A, I get an A and in universe F, I get an F. So is it a must that I get an F because such a probablilty exists in another universe? Will I trip and fall "at the same time" I am not? Almost like a determinism type universe.
You mean to say that multiverse theory can be solved?
I suppose if you take the multiverse thing literally, then yes, any event that has a nonzero probability of happening actually does happen in some universe. But who knows, if you are a great student maybe there is zero probability that you get an F. :wink:
Anyway, I don't think you can identify yourself with your multiverse copy. If you get an A, then you're in universe A and that's it. There's someone almost exactly like you in universe F who got an F, but that person is not you.
What makes "me" me? If someone is exactly like me, what separates them from me?
I would like to attempt answering this;
What separates you from them is that you are an Ego and there appears to me no way you can avoid this. In choosing what is to be believed, or what actions are to be pursued, the process only supports that an Ego is at work.
When Hypnagogue says;
…I don't think you can identify yourself with your multiverse copy.
I believe he is correct.
Now inspect the wording of your last post;
Note the part above I emboldened; you recognize your Ego and call it “me”. You call it “me” even while considering the ramifications of the existence of others exactly like you. If such an individual, instead of existing in a parallel universe, was standing in the room next to you, could not the question still be asked; what separates you from me? Whatever the answer to that question might be are you not, in asking, acknowledging a difference does in fact exist?
I call it the Ego, the acting man.
To expand on what BH said, that which delineates the boundaries of your identity is simply the boundaries of your own consciousness. In a sense, you are not me just because your consciousness is not my consciousness; if our consciousnesses somehow merged together, wouldn't we become one entirely new person? Likewise, you are not your multiverse copy because your consciousness is distinct from that of your multiverse copy. (If it weren't, you'd feel the disappointment of your multiverse copy's F, and so on.)
speaking of multiverses...
I found a transcript from a BBC documentary concerning multiuniverses. It says :
"NARRATOR (DILLY BARLOW): Imagine you could find an explanation for everything in the Universe, from the smallest events possible to the biggest. This is the dream which has captivated the most brilliant scientists since Einstein. Now they think they may have found it. The theory is breathtaking and it has an extraordinary conclusion: that the Universe we live in is not the only one."
here is the URL: http://www.bbc.co.uk/science/horizon/2001/parallelunitrans.shtml
I was under the impression that m-theory was what [apparently] held the key to an explanation to everything in the universe. I don't see how parallel universe produce a unifying theory.
Boulderhead:
How would you define an ego? It is an intriguing concept.
What would be the difference if you said "…I don't think you can identify yourself as your multiverse copy." instead of "…I don't think you can identify yourself with your multiverse copy. " ?
Here is another article which claims that multiuniverse theory describes how the mind interacts with matter.
Recent discoveries in quantum physics (the study of the physics of sub-atomic particles) and in cosmology (the branch of astronomy and astrophysics that deals with the universe taken as a whole) shed new light on how mind interacts with matter. These discoveries compel acceptance of the idea that there is far more than just one universe and that we constantly interact with many of these “hidden” universes.
What is your take on this? Does multiuniverse theory describe how the mind interacts with matter? If so, is it indirect?
Post a link to the article. As far as I know, anyone doing actual research on the neural basis of consciousness (or the neural interface if that is what you think it is) does not take seriously the idea that any new theories of physics will be necessary for a complete understanding.
That's rather strange. You are presupposing this thing exists and then using curious definitions of "you" and "matter" and so forth. Basically you are making an equivocation between all conceivable circumstances and essentially asserting that there is no value. You're not really heading into a discourse on determinism though you are really asking about value when you have seemingly destroyed value. Would make for a good episode of Stargate or something I guess, though. =)
*Nico
I think the article is bunk. We have been following the latest theories of quantum theory and cosmology on the various physics and astronomy boards, and none of these theories say anything at all about consciousness. So I'm betting the people who claim they do are fantasizing on their own acount, not referencing the brane theories, M-theory, string field theory, quantum geometry or quantum gravity that are actually produced by scientists.
Are you sure? There are a finite number of particles in the universe (a very, very large number, to be sure, but still finite). Are there an infinite number of possible states for a particle to be in? If not, then there will be a very, very, very large number of universes, but not an infinity of them.
:surprise:
:surprise:
Nereid, some eigenvalue sets are continuous. Wouldn't there be a world for every point on a line segment in that case?
Whether or not there are an infinite number of states for a particle to be in, I was thinking more along the lines of the infinity of possible trajectories for these particles to take.
Even assuming that the multiverse theory is correct, the fact that both possibilities exist that you get an A and an F is no reason not to care wether you get one or the other.
Because even if both possibilities exist, the probabilities of both outcomes are not the same. If you are a good student, there will be more probabilities that the outcome is A. Therefore there will be many universes in which you get an A and very few where you get an F.
About the consciousness issue...
Several interpretations of quantum theory, starting by the Copenhagen and other typical ones such as John Wheeler's, give an important role to the conscious observer in collapsing the many probabilities into a fixed reality (in the multiverse language, in selecting in which multiverse version do we continue our -ego- existence)
Well, it is continuous for the sake of simplicity. But if you take that, for instance, the Planck length is the smallest thinkable position resolution, and the Planck time is the smallest thinkable time resolution, then in the *visible* universe there are only a finite (but very very big) number of space-time events. The number of dimensions in the corresponding Hilbertspace would be still much bigger, but finite. In fact, sometimes, very big numbers are more mindboggling than simply saying "infinity" :-)
cheers,
Patrick.
It is indeed remarkable that no matter how you turn around quantum mechanics, the "conscious observer" always seems to sneak in :-)
cheers,
Patrick.
PS: I started a thread on the quantum physics board, but it died out I think, on what I think is a technical difficulty in the multiverse theory, here:
https://www.physicsforums.com/showthread.php?t=39773
cheers,
Patrick.
cheers,
Patrick.
That's assuming there's no length smaller than the Planck length. I don't know any firm evidence that the universe is discrete rather than continuous, do you? Even the latest mutations of string physics, such as AdS/CFT, assume continuous.
I'm not entitled to make any judgement, I'm just an amateur.
I personally don't feel comfortable with the idea that consciousness is required to define the status of the universe.
Also I did not mean that any of the current mainstream theories can "explain" anything about consciousness.
I just meant that according to what I read (popular science), several interpretations of quantum theory require the element "consciousness" -or observer- (if I understood correctly).
I went through your thread about "many worlds", I think I got the point but I have to admit I'm not trained enough to discuss, got to learn a lot still !
Yet just as concept, many-worlds, even if hard to swallow, seems to me the one which can better cope with most of the puzzles we face.
Cheers from Spain,
No, I didn't mean that. I just meant to say that instead of using the position operator with delta(x-a) as eigenfunctions, you could use one with a gaussian of width the Planck length, and limit yourself to a finite set of these, if you do not consider extensions beyond the size of the visible universe. That makes up a finite number of eigenfunctions of the position operator. I didn't mean to say that there's some discrete structure to the nature, but just that for all practical purposes we don't need an infinite hilbert space. I was guessing that the highest attainable resolution of a position measurement would be of order the Planck length (before your ruler collapses into a black hole), but you could easily say 1/1000 * Planck length, it doesn't change the idea that in principle, there are only a finite number of resolvable spacetime events in the *visible* universe in a given time lapse.
cheers,
Patrick.
  • · Replies 23 ·
