Calculating acceleration and brake force
by cyberhev
Tags: acceleration, brake, force
cyberhev
cyberhev is offline
#1
Dec30-08, 06:38 AM
P: 6
1. The problem statement, all variables and given/known data Hi all, the question for revision is; A car of mass 600kg travelling at 45m/s comes to rest in 12m when the brakes are applied. What is the average force exerted by the brakes?
2. Relevant equations Force = mass x acceleration V^2=u^2 +2as
3. The attempt at a solution I know I need to work out the acceleration but am having trouble correctly transposing that equation I think its this v^2-u^2 divided by s =2a, its what to do with the 2 to get a on its own, does it then become 1/2 s on the other side?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Redbelly98
Redbelly98 is offline
#2
Dec30-08, 07:27 AM
Mentor
Redbelly98's Avatar
P: 11,989
Quote Quote by cyberhev View Post
You're using the correct equation, but it looks like you need some help in "solving for a" to get the acceleration.
Let's write out what you correctly have so far:
[tex]
\frac{v^2-u^2}{s}=2a
[/tex]
Hopefully that helps you see better what to do ... if not, then post again.
p.s. I'm not quite sure if
1/2 s
means "(1/2)s" or 1/(2s).
cyberhev
cyberhev is offline
#3
Dec30-08, 07:47 AM
P: 6
That is what i have so far, Im just not sure where the 2 goes so you just get a on its own, I was wondering the 2 then moves to the side of s to become1/2s.
cyberhev
cyberhev is offline
#4
Dec30-08, 07:53 AM
P: 6
If I solve that equation with 2a. I did the following 45x45-0x0, divided by 12 = 168.75 x 2 =337.5. Is this the correct acceleration?
Saladsamurai
Saladsamurai is offline
#5
Dec30-08, 08:00 AM
Saladsamurai's Avatar
P: 3,012
[tex]\frac{v^2-u^2}{s}=2a[/tex]
[tex]\Rightarrow \frac{v^2-u^2}{2s}=a[/tex]
cyberhev
cyberhev is offline
#6
Dec30-08, 08:15 AM
P: 6
Yes I have it, thank you, my transposition of equations knowledge is in there, but its 15 years or so since I used it! I often write the suvat list out, i find it very helpful.
Register to reply
Related Discussions
Calculating acceleration.. Introductory Physics Homework 6
calculating velocity or acceleration General Physics 1
calculating normal force and net force of 20 kg mass going down inclined plane at... Introductory Physics Homework 11
Car brake-pedal force.... Mechanical Engineering 8
Car Brake Performance Using Disc-Brake Variations Mechanical Engineering 2
