Symmetric/Antisymmetric states in nature?
  • Context: Graduate
  • Thread starter Thread starter hendriko373
    Nature States
The discussion revolves around the nature of symmetric and antisymmetric states in quantum mechanics, particularly in the context of identical particles. Participants explore whether these states are a consequence of experimental facts, mathematical formulations, or fundamental postulates within quantum mechanics and quantum field theory.
  • Some participants propose that symmetric and antisymmetric states are required for identical particles due to the indistinguishability of particles, which is mathematically represented by the commutation relations involving the permutation operator.
  • Others argue that the eigenvalues of the permutation operator must be ±1, leading to the conclusion that once a system is in a symmetric or antisymmetric state, it remains in that state under the action of observables that commute with the permutation operator.
  • A later reply suggests that the requirement for states to be symmetric or antisymmetric arises from the nature of indistinguishability, which necessitates that all operators commute with elements of the permutation group.
  • Some participants mention that the Hilbert space for bosons is only the symmetric part, while for fermions it is the antisymmetric part, noting that this distinction is a postulate in quantum mechanics rather than a derived result.
  • One participant presents a proof regarding the non-existence of mixed states under the assumption of indistinguishability, although they express uncertainty about the validity of their argument.
Participants express various viewpoints on the reasons behind the necessity of symmetric and antisymmetric states, with no clear consensus reached. The discussion remains unresolved regarding the foundational implications and the nature of mixed states in relation to indistinguishability.
Limitations include the dependence on definitions of indistinguishability and the assumptions made regarding the properties of operators in quantum mechanics. The discussion also touches on the transition from quantum mechanics to quantum field theory without resolving the implications of this transition.
hendriko373
For the composite system of identical particles only symmetric and antisymmetric states in the tensor-product (from the one-particle spaces) space are allowed to represent particles in nature. Why is that?
Is it an experimental fact which is used as an input in the theory of many particle QM?
Or
Is it a consequence of the commutation relation [tex]\left[P,Q\right]=0[/tex] with P the permutation operator and Q an observable (this commution relation is just the mathematical formulation for the indistinguishability of our many particle system)? This would conclude that P and Q have a common eigenbasis (but which space would span this basis?) whereas the eigenvectors from P are (anti)symmetric so that the action of Q on the system also puts the system in a (anti)symmetric state?
thanks in advance,
Hendrik
I think it's precisely due to the second one (with Q the Hamiltonian). Whenever two hermitian operator commutes, you can simultaneously diagonalize both of them. The eigenvalues for P must be ±1 since P^2=1.
Alright, this means that once your system is (anti)symmetric it stays that way because every observable commutes with P. But this does not explain why a many particle state is (anti)symmetric in the first place (or does it, and if so could you please clearify this)?
Ok, maybe this is the explanation: because of the very nature of indistinguishability every operator Q must commute with every element of the permutation group. But this can only be true for symmetric or antisymmetric states, which form invariant subspaces of the product space of the one particle spaces, under permutations. These subspaces are the only two one dimensional invariant subspaces of the product space (or put it another way: the only two one dimensional representations of the permutation group). Other states belong to more dimensional representations and are rotated in a more dimensional invariant subspace (which alters their physical meaning and thus the eigenvalue of Q).
Actually I'm not sure about the last sentence, because although the permutation elements rotate the states I still think they stay in the same eigenspace of Q.
Any comment would be helpful!
Hendrik
Well, there is a theorem that says whenever two hermitian operators commute, you can choose a basis that simultaneously diagonalizes both of them. Usually, it is a choice that we make. In general, we can decomposes the Hilbert space into (edit) direct sums of symmetric and antisymmetric parts. Of course, at the end of calculations, the conclusions are independent of what basis you choose.
Now, then why is the hilbert space of bosons only the symmetric part? This is a postulate in QM and cannot be proved under its framework. The fact that particles are indistinguishable (i.e. all Q commutes with with P) forbid the existence of mixed state. By completeness of the hilbert space, then it must contain only the symmetric part or the antisymmetric part. This doesn't say anything about bosons or fermions though.
You can, however, go to second quantizations (in the framework of QFT), and show the postulate comes from imposing the relations
[tex][\phi(x), \pi(x')]_\pm=i\hbar \delta^{3}(x-x')[/tex]
Where plus indicates anti-commutation (for fermions) and minus indicates commutation (for bosons). This is simply a postulate of QFT and cannot be proved. The reason why we use anticommutation instead of commutation comes from spin statistics theorem which I don't know too much myself (which comes from Lorentz invariance, Locality and a couple other things...)
Why is that? Because for these states not all Pij commute with each other?
So if I understand you well: it is within the framework of QM that we can conclude that only symmetric and antisymmetric states are physical. But to know which particles belong to the symmetrical part and which to the antisymmetrical we have to get into QFT.
After some thinking, it seems that the reason why mixed state doesn't exist is quite delicate..
In usual QM texts, it is simply asserted that for indistinguishably to hold, the action of P on any subspace must be that subspace itself, hence P|a>= factor* |a>. I believe that this statement is equivalent to P commuting with all possible hermitian operators...
Here is a proof I just thought of:
Suppose P|ψ> = |ψ'>, |ψ'> does not lie in the subspace spanned by |ψ>. Let
|ψ'>=a|ψ>+ b|φ>. |ψ> and |φ> are orthonormal.
Fix any unitary operator, U that maps |ψ> to |ψ> (using Gram-Schmidt process if you wish), but rotates other vectors such that U|φ>≠ |φ'> (just make U|φ>=-|φ>). It can be proved that U=exp(iH) for some hermitian operator (H≠0 since U≠1). [H,P]=0 hence [U, P]=0.
but [U,P]|ψ>=U|ψ'> - P|ψ>=U|ψ'> - |ψ'> = 0
but U|φ>≠|φ>
we have our contradiction.
I just thought of this proof right at the moment so its validity is questionable. Feel free to question anything that seems kinda sketchy. The U=exp(iH) part can be obtained by diagonalizing U and noticing all eigenvalues of U, λ obey |λ|=1.
