Thread Closed
Is C bigger than R?
Share Thread Thread Tools
Jan4-09, 12:20 AM   #1
Is C bigger than R?
Is it true that the set of complex number is bigger than the set of real numbers?
I know that card C = card (R x R) and I think that card (R x R) > card R. Is this true, and if so, why?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan4-09, 02:03 AM   #2
Recognitions:
Gold Membership Gold Member
Quote by samkolb View Post
I think card (RxR) = card R
I would show this by setting up a one-to-one map between RxR and R
I will just show you a one-to-one between the unit square [0,1]x[0,1] and the unit interval [0,1]
You just look at the two decimal expansions and merge
(0.abcdefg...., 0.mnopqrs....) -> 0.ambncodpeq.......
Jan4-09, 03:19 AM   #3
C is with cardinality c, or aleph if you want, the same as R.
The simple bijection is a+ib |-> (a,b) into RxR.
If you want a bijection from C to R, then z=x+iy|->Im(z)/Re(z) it's a bijection to [-infinity,infinity] which is RU{infininity,-infinity} this cardinality is aleph+2=aleph.
QED
Jan4-09, 04:46 AM   #4
Is C bigger than R?
Quote by loop quantum gravity View Post
How could that possibly be a bijection? Obviously, [tex]z_1=a+ib[/tex] is mapped to the same point as [tex]z_2=a z_1[/tex], so it is not an injection.
Marcus has already provided a valid bijection, his "decimal merging" is the classical example of this. Notice how it is also valid in [tex]\mathbb{R}^n[/tex].
Jan4-09, 05:31 AM   #5
Correct Big-T, but at least it's onto.
Jan7-09, 03:39 AM   #6
|C| = |R2| = |R|.
There's some discussion about that in this thread.
Minor point: marcus's function isn't even well-defined; consider decimal expansions with infinite trailing "9"s. (For example, 0.0999... = 0.1000..., but (0.0999..., 0.0000...) maps to 0.00909090..., and (0.1000..., 0.0000) maps to 0.10000000... .) However, the mapping from 0.abcdefgh... to (0.acef..., 0.bdfh...) is a well-defined surjection from [0, 1) to [0, 1)2, and that's all you need.
Jan7-09, 07:26 AM   #7
Marcus' function would be well defined if we agreed to use trailing nines wherever the decimal expansion is terminating, this should of course have been specified.
Thread Closed
Thread Tools
Similar Threads for: Is C bigger than R?
Thread Forum Replies
Further looks bigger beyond z = 1.6 Cosmology 6
What if the moon was bigger? General Astronomy 13
Bigger Sum General Math 1
Which is bigger, a^b or b^a? Set Theory, Logic, Probability, Statistics 20
My Ph.D is bigger than yours General Discussion 12
