Thread Closed
constaint to a rolling object
Share Thread Thread Tools
Jan4-09, 05:03 PM   #1
KFC
A cylinder, radius R, mass M and moment of inertia I, is rolling on a horizontal surface without slipping and a constant force F is exerted on the center of the cylinder horizontally to the right. Try to find the friction by solving the Lagrangian equation.
2. The attempt at a solution
Since the object is rolling without slip, there must be a friction force exerted at the contact point to the left.
When we go to the Lagrangian mechanics, let's call the center of the cylinder (x, y) and the angle made by a specific point on the edge of the cylinder to the vertical line passing through center [tex]\theta[/tex]. Since the object is moving on the horizontal level, no potential. The constraint for no-slipping action is
[tex]f = R\theta - x =0[/tex]
The Lagrangian is
[tex] L = \frac{M}{2}\dot{x}^2 + \frac{I}{2}\dot{\theta}^2[/tex]
The Lagrangian equation is
[tex]
\frac{d}{dt}\frac{\partial L}{\partial\dot{x}} = \lambda \frac{\partial f}{\partial x} = -\lambda
[/tex]
and
[tex]
\frac{d}{dt}\frac{\partial L}{\partial\dot{\theta}} = \lambda \frac{\partial f}{\partial \theta}
= R\lambda
[/tex]
where [tex]\lambda[/tex] is the Lagrange undetermined multiplier. From these equations, I get [tex]\lambda=F[/tex], but how do I relate undetermined multiplier to friction?
If we start from newton's law, it is very easy to solve for the friction, which is obvious written in terms of F. But from my solution above, seems cannot get the same form. What's going on with my solution?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Thread Closed
Thread Tools
Similar Threads for: constaint to a rolling object
Thread Forum Replies
Object rolling off a sphere.... Introductory Physics Homework 2
Energy of a Rolling Object Introductory Physics Homework 4
Object rolling down an incline Introductory Physics Homework 2
Object Rolling up ramp Introductory Physics Homework 6
Rolling rigid object General Physics 1
