Why is the Height of a Mass Launched by a Spring Dependent on its Mass?
  • Thread starter Thread starter syang9
    Spring Two masses
The discussion revolves around the physics of a mass launched by a spring, specifically examining the relationship between the mass of the object and the height it achieves upon launch. The original poster references a scenario involving two masses, one being twice as heavy as the other, and questions the implications of energy transformations in this context.
  • Participants discuss the transformation of elastic potential energy to kinetic energy and then to gravitational potential energy, questioning how these relationships imply mass independence in height. There are inquiries about the validity of equating different forms of energy and the implications of launching two masses together versus separately.
The discussion is active, with participants exploring the nuances of energy equations and their implications. Some guidance has been provided regarding the relationship between launch speed and mass, but multiple interpretations and confusions remain regarding the dependency of height on mass.
Participants are navigating assumptions about the problem setup, including whether the masses are launched together or separately, and how this affects the energy distribution and resulting height.
syang9
this problem came up in my mcat physics prep book. two masses, one twice as massive as the other, are placed on a platform atop a spring. when they're launched, what height do they achieve?
i know they reach the same height, and from a previously archived thread on this board, i understand (somewhat) the reason.. the elastic potential energy is first transformed to kinetic energy, which is then transformed to gravitational potential energy. equating the formulas for those two energies results in an expression that is independent of mass.
what confuses me is that this seems to imply that the height of a mass launched by a spring is independent of mass altogether. this is clearly false.. could someone explain why?
also, why is it incorrect to simply equate the elastic potential energy to the gravitational potential energy? this yields an expression that is clearly dependent on mass.
For a given launch speed, the height reached is independent of mass (equate KE to GPE). But the launch speed depends on the mass (equate the spring PE to KE).
It doesn't imply that.
Can you state the exact problem?
It's not incorrect at all.
Perhaps you are mixing up (1) Two masses launched together, with (2) Each mass launched separately?
hi syang9 ! :smile:
I'll just add this to what Doc Al :smile: has said:
you can equate them, but how would that tell you how much of the energy goes to one mass, and how much to the other? :wink:
so then, the reason that two masses launched together reach the same height is because the launch speed is determined by the total mass, right? after they are launched, they must reach the same height because they are traveling at the same speed.
Right!
