Standard deviation for a determinate state of observable Q
The discussion revolves around the concept of standard deviation in quantum mechanics, particularly in relation to determinate states of an observable Q. Participants explore the mathematical expressions involved, the roles of operators versus values, and the implications for calculating standard deviations and expectation values.
  • Some participants express confusion about why the operator Q is used in the standard deviation expression instead of the value Q, questioning if this leads to errors or if it is a necessary distinction.
  • There is a discussion about the expectation value of an operator versus a number, with some participants asserting that the operator must act on the state to find its expectation value.
  • One participant emphasizes that before calculating standard deviation, one must operate on the wavefunction with the corresponding operator, suggesting that discussing the value of E is meaningless without this context.
  • Another participant proposes a calculation for the standard deviation of energy using a specific wave function, but questions the notation used for operators.
  • There is a clarification that operators must be denoted with a hat to distinguish them from values, and that the expectation value is specifically for the operator.
  • Some participants debate whether it is permissible to write the operator within the average brackets directly or if it should be represented as a value first.
  • The distinction between the average of a value and the average of an operator is raised, with some seeking further clarification on this difference.
Participants exhibit disagreement regarding the use of operators versus values in expressions for standard deviation and expectation values. The discussion remains unresolved with multiple competing views on the proper notation and conceptual understanding.
Participants express uncertainty about the implications of using operators versus values in quantum mechanics, and there are unresolved questions about the mathematical steps involved in calculating standard deviations and expectation values.
armis
In general, identical measurements on identically prepared systems do not yield reproducible results; however, some states are determinate, for a particular observable, in the sense that they always give the same result. For a determinate state of observable Q, the standard deviation is zero:
[tex]0=\sigma^{2}_{Q}=\langle(\hat{Q}-{\langle}Q{\rangle})^2\rangle=\langle\psi\mid(\hat{Q}-{\langle}Q{\rangle})^2\psi\rangle[/tex]
J.Griffiths
There are two things I don't understand here:
Firstly, why in the standard deviation expression we use the Q operator instead of the Q value itself? Writting Q seemed more natural and then in the next expression I would just stick the corresponding operator. Which would lead to the same result or is it just two errors cancelling each other?
Secondly, why in the last expression we are not using an operator of the quantity that was in the previous expression under the "average" brackets? Is it an operator of itself like coordinate x is for example?
Expectation value of a number is just a number, you want the operator Q to act on the state to find its expectation value.
So for instance <psi|<Q> |psi> = <Q>
Nothing "happened" since <Q> is just a number.
but what is <Q> ? that you must evaluate.
You could recapitulate what standard deviation and expectation value is in theory of statistics in math.
This I know
Is there a difference? I think there is none. Feel free to correct me
Let me clarify. First of all I don't understand why in this expression
[tex]\sigma^{2}_{Q}=\langle(\hat{Q}-{\langle}Q{\rangle})^2\rangle[/tex]
we use the operator Q instead of the value Q.
For example if we make repeated measurements on identically prepared systems we may get a bunch of different Q values, we take their average and hence we can calculate the standard deviation. So why use an operator?
difference between what?
Okay let's make an example.
Caclulate the standard deviation for the Energy for this wave function:
[tex]\Psi _E = 2\psi _{E1} -3\psi _{E2} + 4\psi _{E3}[/tex]
Where [tex]\psi _{Ei}[/tex] is the energy eigenstate to the Hamiltonian with energy i MeV.
What is the "value of E" here? It is meaningless to talk about it before one has operated on the wavefunction with operator.
You want to calculate the standard deviation, not measure it.
Cool, I like this kind of approach :)
Well, I think it would look like this, right?
[tex]\sigma^{2}_{H}=\langle(H-{\langle}H{\rangle})^2\rangle=\langle\psi\mid(\hat {H}-{\langle}H{\rangle})^2\psi\rangle[/tex]
Notice I didn't write the hat on H in the second expression ( the part I don't understand )
Then I would stick in the wave equation you gave me and start multiplying the members. The orthogonal eigenstates would give zero while others would sum up to a number thus I will end up with a certain value. Is that correct?
no you must "hat" them to denote that they are operators.
[tex]<(\hat{H} - < \hat{H} >)^2 > = <\hat{H} \hat{H} > - <br /> < \hat{H} >^2[/tex]
Then you can start with:
[tex]<\hat{H}> = \int (2\psi _{E1}^* -3\psi _{E2}^* + 4\psi _{E3}^*)\hat{H}(2\psi _{E1} -3\psi _{E2} + 4\psi _{E3}) =[/tex]
You must learn what is meant by [tex]< \hat{Q} >[/tex]
It is the expectation value for the operator [tex]\hat{Q}[/tex]
What if Q operator was the momentum operator in position space for instance?
You must also learn what the relation between operators and states is.
So what you are saying is that I can already write the operator within the "average" brackets like this [tex] < \hat{Q} > [/tex]?
I thought I was not allowed to do that and had to write [tex] < Q > [/tex]
instead and only once I am trying to compute the expectation value I sandwich the corresponding operator between the wave functions.
The average of a value is simply the value, the average of an operator is totally different.
What is the the average of an operator ?
