Electromagnetic wave reflection
The problem involves the Doppler effect as it relates to an electromagnetic wave emitted by a police radar gun and reflected off a moving vehicle. The scenario includes a police car moving at a constant speed and a speeder moving away from it, with specific frequencies given for the emitted and received waves.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the Doppler effect, with some suggesting the need to use the Doppler equation twice for the emitted and reflected waves. Questions arise regarding the interpretation of the frequency value provided and its implications for the calculations.
Participants are exploring various interpretations of the problem and the correct application of the Doppler effect. Some have attempted to clarify the frequency value and its significance, while others are sharing their approaches and expressing uncertainty about the calculations. There is no explicit consensus on the correct method yet, but hints and guidance have been provided to help the original poster progress.
There are indications of urgency due to a deadline, with one participant mentioning a time constraint related to submission. Additionally, there is confusion about the frequency value, with discussions about whether it is correctly understood as a radio frequency.
adashiu
A speeder is pulling directly away and increasing his distance from a police car that is moving at 29 m/s with respect to the ground. The radar gun in the police car emits an electromagnetic wave with a frequency of 8.0x109 Hz. The wave reflects from the speeder\'s car and returns to the police car where its frequency is measured to be 318Hz less than the emitted frequency. Find the speeder's speed with respect to the ground.
Should I use here Doppler's Effect?
u - speed of light
Vs - speed of speedster
Vo - speed of observator(police car)
f'=fo*[tex]\frac{u+Vs}{u-Vo}[/tex]
You will need to use the doppler equation twice, once for the emitted sound wave and again for the return sound wave. If you want me to solve it and show you how you will just need to clarify when you say "8.0x109 Hz" do you really mean 8.0x109 Hz or do you mean 8.0x10^9 (8 times 10 to the exponent of 9).
8*109 meaning 872... Thank you for help. Generally i have no idea how to use Doppler's equation twice in this case...
badreligion said:
... If you want me to solve it and show you how ...
Please note that doing that is against Physics Forums policy:
"On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Under no circumstances should complete solutions be provided to a questioner, whether or not an attempt has been made."​
For more details, click on "Rules" at the top of this page, then scroll down to the "Homework Help" section.
Hopefully, your good hint of applying the Doppler shift twice will get the OP on the right track.
Regards,
Mark
Anyway, I had some attempts, probably not correct. I need it for tommorow. Its 1 AM here, so in like about 8 hours I will be kicked out by a professor from room, because I don't have this done
Here is the formula I use, it is the same thing as yours just simplified.
f'=(1+Vobs/Vsnd)f
First Doppler Shift
f'=(1+29m/s / 343m/s)*872Hz
Second Doppler Shift
f''=f'/(1+Vsource/Vsnd)
872Hz-318Hz=f'(1-n/343m/s)
554Hz=f'(1-n/343m/s)
554Hz/f'=1-n/343m/s)
(554Hz/f')-1=n/343m/s
Cross Multiply
((554Hz/f')-1)*343m/s=n
There you go hopefully you can understand that. 343m/s is the speed of air at a normal temperature. n is what you solve for and f' you find in the first doppler shift. I think I worked everything out right, good luck.
No, I don't think you mean that. (872 Hz is not a radio frequency. 8.0 x 109 Hz IS a radio frequency.)
You can start out using it once, and get an expression relating the following:
  • the frequency of the wave "received" by the speeding car, and
  • the speed of the car relative to the police
I had the same feeling not only does the frequency make more since, but so does the answer when it is 8.0 x 109 Hz
I will ask my teacher, what actually this value is, but now I have a pattern how to solve it
thanks ;]
9K
