| Thread Closed |
Wave Optics - Single Slit Diffraction |
Share Thread | Thread Tools |
| May30-04, 09:35 AM | #1 |
Light of wavelength 600nm falls on a 0.40-mm-wide slit and forms a diffraction pattern on a screen 1.5m away.
(a) Find the position of the first dark band on each side of the central maximum. (b) Find the width of the central maximum For the (a) I think that we use sinθ = +- λ / α I think m is equal to : m = +- 1 Where λ = 600 nm and α = 0.40 mm If the way I have solved (a) is correct, then how do I proceed to (b) ? I know L is 1.5m then what? |
| May30-04, 04:55 PM | #2 |
Recognitions:
You use trig. That θ in the equation is the angle for a particular right triangle. There should be a picture in your book. L is one leg and the width of the central max is twice the other leg.
Actually, that equation you used for (a) may need an adjustment. I'll get back to you. I think that destructive interference occurs for the condition: (α/2) sinθ = λ/2 Oh, sorry. You just manipulated it. The way you have it should be correct.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Wave Optics - Single Slit Diffraction
| Single slit diffraction? | General Physics | 4 | ||
| single slit diffraction / wave propagation | Classical Physics | 1 | ||
| Single slit diffraction | Introductory Physics Homework | 1 | ||
| Single Slit Diffraction | General Physics | 1 | ||
| Single-slit Diffraction | Introductory Physics Homework | 1 | ||
