Entering the Sphere of Influence
  • Context: Graduate
  • Thread starter Thread starter Venus50
    Sphere
The discussion centers on the trajectory correction of space probes entering the Sphere of Influence (SOI) of planets, specifically referencing Larry Bogan's article on gravity assists. It is established that a space probe's trajectory is calculated to avoid collision with the planet upon entry into the SOI, utilizing an Impact parameter to ensure a safe distance. Trajectory corrections can be made at various points, but ideally should occur before the probe reaches the interception point to adjust for velocity changes. The calculations of relative velocity at different points are crucial for determining the necessary angle for trajectory correction.
  • Understanding of Sphere of Influence (SOI) in astrodynamics
  • Familiarity with gravity assist maneuvers
  • Knowledge of trajectory correction techniques
  • Basic principles of orbital mechanics
  • Research the concept of Impact parameter in orbital mechanics
  • Learn about trajectory correction maneuvers for interplanetary missions
  • Study the calculations involved in determining relative velocity at different orbital points
  • Explore the principles of gravity assists and their applications in space exploration
Aerospace engineers, astrodynamics researchers, and students studying orbital mechanics will benefit from this discussion, particularly those involved in mission planning for space probes.
Venus50
In an article by Larry Bogan " The Orbit of a Space Probe from Earth to Jupiter",it mentioned about a slingshot or gravity assist by the planet-Jupiter and this could change the orbit and velocity of the space probe that leaving the Sphere of Influence[SOI].In entering the SOI of the planet[by the already calculated Transfer Orbit of the space probe] the space probe would intersect with the planet's orbital path at an angle and a velocity. This means that the space probe would exactly hit the planet if no any trajectory correction is made during entering the SOI.The trajectory correction of the space probe should be made by controller on Earth,right?,to avoid collision with the planet.What I wonder and would like to ask is ,[1] at which point the trajectory correction of the space probe should be made?At the point of entry to SOI or it could be at any point closer to the planet,of course,before collision occurs.[2]The velocity of the space probe at the point of entry to SOI would not be the same as that at the interception point[the point of Rendezvous],right?. So,actually,the calculations of the space probe velocity relative to the planet by different values[point of entry vs interception point]should give different space probe relative velocity to the planet and hence the direction of the vector. This would affect the "Angle of Trajectory Correction". Is that right? Thank you so much.
Astronomy news on Phys.org
Really? Why is that?
No. The probe is given a trajectory upon launch that would cause it to miss the Planet by some distance (called the Impact parameter). By picking the right trajectory at launch, you get just the right exit angle and velocity you want upon exiting the SOI. The only reason the probe would be on an course to hit the planet would be if that was the purpose of the mission.
  • · Replies 86 ·
9K
  • · Replies 30 ·
  • · Replies 29 ·
