Light waves through grating. Min and Max measurements of wavelenghts in nm
The discussion centers on calculating the minimum and maximum wavelengths of light passing through a 220 lines/mm grating, observed on a screen 1.4m wide and 1.2m behind the grating. The relevant equations include y = L tan(Ø) and d sin(Ø) = m * wavelength. The user initially misinterpreted the line density and struggled with the calculations, leading to incorrect wavelength values. Correct understanding of the grating spacing (d) and proper application of the equations are crucial for accurate results.
  • Understanding of wave optics principles
  • Familiarity with grating equations and terminology
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to convert units, particularly between mm and nm
  • Study the principles of diffraction gratings and their mathematical models
  • Learn how to derive and apply the grating equation d sin(Ø) = m * wavelength
  • Explore unit conversion techniques, especially for wavelength measurements
  • Investigate the relationship between fringe spacing and wavelength in diffraction patterns
Students in physics, particularly those studying optics, as well as educators and anyone involved in experimental physics related to wave phenomena.
Mugen112
Light passes through a 220 lines/mm grating and is observed on a 1.4m wide screen located 1.2m behind the grating. Three bright fringes are seen on both sides of the central maximum.
What are the minimum and maximum possible values of the wavelength?
Express your answers in nm.
y=LtanØ
dsinØ=m*wavelength
I started by looking at the first equation that is listed. y=LtanØ
To find y, I just looked at the 220lines/mm and that is .00022lines/nm. So then I just converted L into nm and plugged in the numbers.
700000000 = 1200000000tanØ
then
tan-1(700000000/1200000000) = about 30 degrees? ... I then put that into the second equation and get something wayyyy off for the wavelength. like .00037nm?
I've been working on this problem for over an hour and can't seem to find what I'm doing wrong or how to approach this the correct way. Any help is appriciated. Thanks!
d is the distance between two lines in the grating (hint: it is not a density)
