Register to reply
Taking the derivative of e^3x
by sonofjohn
Tags: derivative
Share this thread:
sonofjohn
#1
Jan11-09, 04:45 PM
P: 76
If f(x) is the function given by f(x) = e3x + 1, at what value of x is the slope of the tangent line to f(x) equal to 2?
I thought the derivative of e3x would be 3e3x because of the chain rule, but it doesn't appear to be correct. I know that ex is just ex, so is e3x just e3x?
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Dick
#2
Jan11-09, 04:56 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
You were right the first time. You need the chain rule. (e^(3x))'=3*e^(3x).
tiny-tim
#3
Jan11-09, 04:56 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
Hi sonofjohn!
Quote Quote by sonofjohn View Post
It is correct who says it isn't?
sonofjohn
#4
Jan11-09, 04:58 PM
P: 76
Ahh thank you very much!
sonofjohn
#5
Jan11-09, 05:05 PM
P: 76
The region bounded by y = e^x, y = 1, and x = 2 s rotated about the x-axis. The volume of the solid generated is given by the integral_____________.
So this is volume problem and a disc/ washer method formula should work best. I was going to set the problem as:
pi(antider)from 0-2 of (e^x-1)^2(1-1)^2 but I don't believe I will come out with 1-1 and 0 as the volume.
Dick
#6
Jan11-09, 05:11 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
You are rotating around the x-axis. At a given value of x what is the outer and inner radius of the washer?
sonofjohn
#7
Jan11-09, 05:16 PM
P: 76
0 and 2, so they would be my bounds so would I rather set the problem up as, pi*antiderv*(e^x-1)^2
tiny-tim
#8
Jan11-09, 05:18 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
Hi sonofjohn!
(have a pi: π )
I don't actually understand all of your (e^x-1)^2(1-1)^2
but you have a π(ex - 1)2, which is not the area of anything, is it?
Dick
#9
Jan11-09, 05:19 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
No, at say x=1 what is the inner and outer radius of the washer? What about at a general value of x? 0 and 2 are fine for the limits on the x integration. Now you just want to find the area of the washer. Correctly, this time. It's not pi*(e^x-1)^2.
sonofjohn
#10
Jan11-09, 05:25 PM
P: 76
Ok so I should find the area of the washer. The area of the washer should be defined as e^x - 1 Also since I am using the dish washer formula, I should square both parts of the integration thus yielding:
pi(anitderivative)(e^2x -1)
Dick
#11
Jan11-09, 05:29 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
Ok. Yes. The area is pi*(outer radius^2-inner radius^2).
sonofjohn
#12
Jan11-09, 05:32 PM
P: 76
Quote Quote by Dick View Post
Thanks for the clarification!
sonofjohn
#13
Jan11-09, 06:08 PM
P: 76
The 3rd problem on this page is difficult for me to understand. I don't understand what the x stands for when they are talking about the bounds in terms of integration. Do they mean the x-axis on the graph or possible x = 2 where at the x intercept?
Dick
#14
Jan11-09, 06:29 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
x is a point between 0 and 4. Any one. What you might notice is that G(x) is the area under the curve from 0 to x. H(x) is NEGATIVE of the area under the curve from x to 2 (because the integral is from 2 to x instead of from x to 2). Might this tell you something about G(x)-H(x)?
sonofjohn
#15
Jan11-09, 06:44 PM
P: 76
So then the answer must be g(x) = h(x) - 2, because h(x) is positive and g(x) is negative. g(x) is also always going to be two less, because it goes from any point to 0, and h(x) only goes to 2.
Dick
#16
Jan11-09, 06:50 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
I can't really agree with you there, sonofjohn. Try this. What are G(1) and H(1)? Work them out from the picture.
sonofjohn
#17
Jan11-09, 07:01 PM
P: 76
I see now that (d) cannot work. Subtracting 2 everytime from h will not yield an equal integral. Now I would like to say that g(x) = h(x+2) would work, but it doesn't seem plausible past h(1). Could G'(x) = H'(x+2) work? I don't even understand what it means.
Dick
#18
Jan11-09, 07:07 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
You didn't answer my last question. What are G(1) and H(1)? That should let you eliminate some possibilities.
Register to reply
Related Discussions
Taking the derivative of a definite integral Calculus 11
Taking Physical Chemistry before formally taking Quantum Mechanics Academic Guidance 17
Replacing total derivative with partial derivative in Griffiths' book Advanced Physics Homework 3
Taking derivative Calculus & Beyond Homework 2
Taking the derivative Calculus 11
