Scaling node coordinates to a fixed graph size
This discussion focuses on scaling node coordinates of various graphs to fit within a fixed size, specifically 500 by 500. The method involves determining the ratio of the desired size to the original size, denoted as B/A, and multiplying all coordinates by this ratio. For instance, if the original x and y coordinates range from 0 to 1000, scaling them to fit within 0 to 500 requires multiplying by 0.5, resulting in transformed coordinates such as (900, 800) becoming (450, 400).
  • Understanding of coordinate systems in graphing
  • Basic knowledge of scaling transformations
  • Familiarity with mathematical ratios
  • Experience with graph layout algorithms
  • Research "Coordinate Scaling Techniques in Graph Theory"
  • Learn about "Graph Layout Algorithms" for maintaining relative distances
  • Explore "Data Visualization Libraries" that support dynamic scaling
  • Study "Mathematical Transformations" for advanced scaling methods
This discussion is beneficial for data scientists, software developers, and anyone involved in graph visualization or layout optimization who needs to maintain the integrity of node relationships while adapting to fixed display sizes.
mcnkevin
Hi, suppose i have various graphs which each have many nodes. In one graph the nodes x and y values may be within the range 0-1000, in another the x values may range from 100-500 and the y values from 300-800. Basically, the ranges always vary and there is no consistency.
I need a way to scale the values of the x and y coordinates such that they fit inside a fixed graph size (say 500 by 500) such that the graph retains in basic layout and relative distances between nodes.
Probably not that hard a question, i just can't figure it out :). Thx for any help.
Mathematics news on Phys.org
If your graph x and y range from 0 to A and you want it to fit inside 0 to B, multiply all coordinates by B/A.
For example, if you x and y coordinates are always between 0 and 1000 and you want it to fit inside 0 to 500 multiply all coordinates by 500/1000= 1/2. So, for example, the point (900,800) would change to (450, 400).
  • · Replies 16 ·
