Hollow cube - moment of inertia
The discussion revolves around calculating the moment of inertia of a hollow cube, focusing on the relationship between the outer and inner cubes and their respective masses.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the idea of subtracting the moment of inertia of the inner cube from that of the outer cube, questioning the appropriateness of this method and the mass values to use in the calculations.
There are various approaches being discussed, including the calculation of mass based on volume and density. Some participants express uncertainty about their reasoning and the calculations involved, while others provide insights into the relationship between mass and volume.
Participants note that the mass of the hollow cube is proportional to its volume, and there is a focus on the density of the cubes involved. The discussion reflects a lack of consensus on the correct approach to calculating the moment of inertia, with some expressing doubts about their previous calculations.
blr
How to calculate moment of inertia of hollow cube.
I guess that subtracting the moment of inertia of the inner cube from the moment of inertia of the outer cube is wrong.
Even it is close to solution, what mass to put in formula?
A good idea to subtract away the inner cube!
The mass of the hollow cube will appear in your answer; if you don't know it just leave it as m.
I know mass of hollow cube, and it is m...
Moment of inertia of cube is m a^2/6.
So moment of inertia of hollow cube is m1 a^2/6 - m2 b^2/6...
I need help with m1 and m2...
The density of the initial solid cube is a constant, so the mass is proportional to the volume. The volume of the removed cube and the volume of the remaining cubic shell are calculable in terms of a and b.
I know that, but I don't know how to do it :(
Thanks for your answers!
What is volume of the cube with an edge length a?
? a^3
Good. What is its mass (assuming density d)?
d a^3
So where is the problem?
So...
I(of hollow cube) = m * [tex]\frac{a^3}{a^3-b^3}[/tex] * [tex]\frac{a^2}{6}[/tex] - m * [tex]\frac{b^3}{a^3-b^3}[/tex] * [tex]\frac{b^2}{6}[/tex]
that is
[tex]\frac{m(a^5-b^5)}{6(a^3-b^3}[/tex]
Is that ok?
anyone?
I don't get it. What is ma^3/(a^3-b^3)?
Mass of hollow cube is given. So that is mass of full cube, before removing inner cube with edge length b.
Ah, OK.
Looks OK to me, but I made so many stupid mistakes lately that I don't trust myself these days.
Thank you...
  • · Replies 40 ·
15K
  • · Replies 28 ·
