| Thread Closed |
Water Balloon Launcher |
Share Thread | Thread Tools |
| Jan12-09, 09:57 PM | #1 |
Given hb (m) = 1 (Height of point B) theta = 30 (degrees - launch angle) k (N/m)= 60 (assume the graph is linear) m (g) = 250 (balloon mass) 1. If Xs (cm) = 150 (pull distance) a) Find the estimated Vb and the landing X (ideal case where Ein =Eout) b) The balloon land 160 ft away. Find the actual Vb for the shot. Find also the Eout and the efficiency of the launcher. 2. Relevant equations 1/2kx^2 mgh 1/2mv^2 3. The attempt at a solution dont know how to solve for a)...not sure with the what i am doing. any hint on what formula i should be using? for b, i put ft into m, so x = 48.7656m and used it to find time, t = 2.439s, which is then use to find Vb, Vb = 23.087m/s so how exactly do i solve for a) and find Eout and the efficiency ? |
| Jan12-09, 11:45 PM | #2 |
Recognitions:
It looks like you have a spring or elastic launcher with a spring constant of k.
Is B the launch point? Vb the launch velocity? If so, (a) involves finding the speed of the balloon when it leaves the launcher. You are directed to use conservation of energy. That is, the energy of the spring is converted entirely into the energy of the moving balloon. Start with SPRING ENERGY = KINETIC ENERGY and put in the formulas for those two types of energy. |
| Jan13-09, 12:26 AM | #3 |
k for Ein=Eout, i did 1/2kxs^2=1/2kmv^2 and got an efficiency of 98.7% Vb ideal is found by V = Squareroot((KXs^2)/m) where Vb is 23.24m/s but i still cant find the X ideal here what i gotten for the approach to X: X=Vo/Cos(theta)t but cant find X if i dont know t(time) X=1/2at^2 + Vbt and using this approach still doesnt help... |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Water Balloon Launcher
| Water Balloon Drop Final Exam Review | Introductory Physics Homework | 1 | ||
| water ballon launcher | Introductory Physics Homework | 5 | ||
| water balloon launching! | Classical Physics | 2 | ||
| Helium balloon in water and air | Introductory Physics Homework | 1 | ||
