| Thread Closed |
Physics Particle Movement Calculations |
Share Thread | Thread Tools |
| Jan12-09, 10:04 PM | #1 |
A particle moves in such a way that its position z, in meters, is given as a function of time t, by the equation z = 2t^2 − 3t^3. At what times is the particle at position z = 0? (two answers; one is 6E-1) 2. Relevant equations z = 2t^2 − 3t^3 3. The attempt at a solution I've tried plugging in certain numbers and i'm trying to figure out what my teacher means by 6E-1. Refreshing my memory of calculus etc.. |
| Jan12-09, 11:39 PM | #2 |
Recognitions:
6E-1 means 6 x 10 to the power -1, which is 0.6.
You can put 6E-1 into your calculator, press ENTER or = and see that. I don't think 6E-1 is a correct solution of that equation. Better check the question again. You have a cubic equation to solve, luckily an easy one. The usual approach is to factor it. Look for a common factor. For example, if you had this equation: 0 = 3x - 9, you would think as follows: The factors of 3x are 3 and x. The factors of the second term, 9, are 3 and 3. The factor in both is 3. So you would write down the 3, put brackets and ask yourself what 3 must be multiplied by to get the original 3x - 9: 0 = 3x - 9 = 3(x - 3) To solve it, you ask if each factor could be zero. 3 can't be zero, but x-3 can. x - 3 = 0 x = 3 (from adding 3 to both sides) example 2: 0 = 2t^3 + t^2 - t t is a common factor of all 3 terms. So 0 = t(2t^2 + t - 1) A method called "trinomial factoring" can be used on the factor in the brackets. It is a bit too complicated to write easily in plain text, so I'll leave you to look it up. 0 = t(t+1)(2t-1) Then t = 0 or t+1 = 0 or 2t-1 = 0 and the 3 solutions are t = 0, t = -1 and t = 1/2 |
| Jan13-09, 01:38 PM | #3 |
Thank you very much for your help!
I came out with the following conclusion: factored z=2t^2-3t^3 into z=t^2(2-3t) so I concluded that one answer is t=0 because 0^2(anything) would = 0 I also thought 2-3(.666666forever don't know how to write that on comp) would also equal 0 because 3*0.6forever would equal 2 so 0.6 was close. Is my thinking right? Thanks again for your help very much appreciated. |
| Jan13-09, 01:59 PM | #4 |
Ok, new question related to this one:
Use Differentiation to find an expression for the velocity of the particle as a function of time. I can't figure out what Differentiation is any ideas Thanks |
| Jan13-09, 05:55 PM | #5 |
If your function was 2t^2-3t^3 you can get t^2(2-3t)=0, so t=o and then: 2-3t=0 ---> -3t=-2 ---> t=(2/3) = .6666 (your teachers answer of 6E-1 i guess). As far as differentiation, when you differentiate a position function, you get a velocity function. When you differentiate a velocity function Im assuming you didnt learn differentiation yet? All you have to know for this question is the power rule: say you have ax^n, to differentiate put it in the form of nax^n-1... So heres an example: 7x^5 ---->after differentiation you get 35x^4 |
| Thread Closed |
| Tags |
| calculation, movement, particle, physics, velocity |
| Thread Tools | |
Similar Threads for: Physics Particle Movement Calculations
| Chemistry Homework-- Stoichiometry: Volume and Particle Calculations | Biology, Chemistry & Other Homework | 1 | ||
| car movement physics | General Physics | 4 | ||
| [SOLVED] Particle movement down a track | Introductory Physics Homework | 12 | ||
| Particle Movement w/o Knowing a or v | Introductory Physics Homework | 4 | ||
| physics of movement | General Astronomy | 6 | ||
