| Thread Closed |
Launcher machine design (Need Help!) |
Share Thread | Thread Tools |
| Jan14-09, 03:36 AM | #1 |
Hi all,
I'm going to design a ball launcher machine, but i've no idea where to start from.. this is the ball type: http://en.wikipedia.org/wiki/Sepak_Takraw how do i judge the power and rpm required for the motor?? as i know, there is a initial velocity required for the roller, so the ball could achieve certain distance. please enlighten me, thank you vey much =) for this tennis ball launcher, the power required for the motor is 154W http://www.ece.uvic.ca/~dwolowic/MechProgress.pdf so perhaps it has to be slightly higher than that, since the size and weight is bigger.. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jan14-09, 01:42 PM | #2 |
Probably the best place to start is to carefully read the report that you already have in hand that details a similar design problem. It gives you quite a lot of information, and it describes a lot of possibilities. Ultimately you will have to go through a similar process for your problem, and your results will probably not be identical to what is in that report. Never the less, it is an excellent place to start.
| Jan14-09, 11:16 PM | #3 |
any recommended website or software for projectile motion??
| Jan14-09, 11:32 PM | #4 |
I don't think you need help nearly as much as you need motivation to start. You have a very good report that lays it all out for you.
If you really need to study projectile motion, this topic is described in countless mechanics texts (dynamics). |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Launcher machine design (Need Help!)
| design a human-powered machine... | Introductory Physics Homework | 5 | ||
| help me in design gearbox problem for milling machine | Mechanical Engineering | 1 | ||
| Stumped on a state machine design | Engineering, Comp Sci, & Technology Homework | 3 | ||
| help on mealy machine design | Electrical Engineering | 1 | ||
