Stationary Points of Inflection
  • Thread starter Thread starter Cummings
    Points
The discussion revolves around identifying stationary points of inflection and understanding the relationship between turning points, local extrema, and points of inflection in the context of polynomial functions. The original poster presents a specific polynomial function and questions the nature of its maximum and minimum values, as well as how to find exact x-coordinates for points of inflection.
  • Participants explore the definitions of turning points, local maxima, minima, and points of inflection, questioning whether maximum and minimum values can be considered points of inflection. There is also a focus on how to obtain exact values for x-coordinates of points of inflection.
Some participants have provided clarifications regarding the definitions of saddle points and points of inflection, noting the importance of the second derivative in determining the nature of these points. There is an ongoing exploration of the concepts involved, with no explicit consensus reached yet.
Participants are working within the constraints of a specific polynomial function and are addressing potential misunderstandings about the definitions and relationships between different types of critical points in calculus.
Cummings
Now, given y=x^3 -9x^2+23x-16 on the interval [-3,7]
the maximum and minimum values would be the turning points right?
also, a stationary point of inflextion is where the grandient is zero, with a positive or negative gradient on both sides right?
i am asked to find the EXACT values of the x-coordinates of the points of inflection on the graph of -x^4 + 3x^3 + 5x^2 + 2x + 11
but, there are two maximums and one minimum, not a stationary point of inflection.
So, are minimum and maximum values points of inflections?
Also, how do i obtain an EXACT value for the x coordinates.
You are mixing together the concepts "point of inflection" and "saddle point"
A "saddle point" is a point where the derivative is zero, but where the function does not achieve a local extremal value.
A "point of inflection" is a point where the curvature changes sign; in particular, the 2.derivative is zero at a "point of inflection".
Since you're given an interval, then you're dealing with local extrema here. I'm not sure what you mean by 'turning point'. I suggest you take a look at the definition of a local max. and min. again.
As arildno said, you're probably getting some of these concepts mixed up. There is a so-called second derivative test which you can use to find whether a given point on the function is a a local maximum or minimum. It basically says:
If for some p, f'(p) = 0 then
- If f''(p) > 0, there is a local minimum at (p, f(p))
- If f''(p) < 0, there is a local maximum at (p, f(p))
- If f''(p) = 0, then you're out of luck.
Hope that helps,
e(ho0n3
Be careful with that. A point of inflection only occurs if the 2nd derivative changes signs, not simply if it is zero. For example, if [tex]f(x)=3x[/tex], then [tex]f''(x)=0[/tex] for all values of x, but there are clearly no inflection points.
But if you look at [tex]f(x)=x^3[/tex], [tex]f''(x)=6x[/tex] and we see that [tex]f''(0)=0, f''(-.1)=-.6, f''(.1)=.6[/tex] and the 2nd derivative is clearly changing signs at x=0, so there is an inflection point there.
Hmm..that's what I meant with ("a point where the curvature changes sign"), but I see now that the last part of the sentence made the meaning ambiguous.
Thx.
  • · Replies 20 ·
