Solving Flotation Problem: Estimate a Polar Bear's Mass
  • Thread starter Thread starter WhackyWookie
The problem involves estimating the mass of a polar bear that partially supports herself on a slab of ice, with specific details about the ice's specific gravity and the bear's volume and weight distribution in and out of the water.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss using the equivalence of ratios between displaced water volume and object volume, as well as the relationship between densities. There are attempts to set up equations based on forces acting on the system, including buoyant forces and weights.
Some participants express frustration with their calculations yielding results that do not match expected answers from a textbook. There is a suggestion to show work and verify units, indicating ongoing exploration of the problem.
Participants are working under the constraints of specific gravity values and the volume of ice, while questioning the assumptions made in their calculations and the validity of the provided answer in the textbook.
WhackyWookie
The problem is:
A polar bear partially supports herself by pulling part of her body out of the water onto a rectangular slab of ice. The ice (with specific gravity of 0.917) sinks down so that only half of what was once exposed now is exposed, and the bear has 70% of her volume and weight out of the water. Estimate the bear's mass, assuming that the total volume of ice is 10 m^3, and the bear's specific gravity is 1.0.
I have tried to solve it using the equivalence of the ratios between the volume of displaced water and volume of object and density of object and density of fluid, but have been consistently getting wrong answers. Any help is appreciated.
WhackyWookie said:
The problem is:
As a general approach, do it like this: You can find out what volume of ice is originally submerged (without the bear on it). Now, set up an equation where the net force is zero. The forces acting on the system would be the buoyant force on 30% of the bear, the buoyant force on the ice (and you should be able to figure out what volume of ice is in the water based on the previous calculation, and the fact that another 50% is submerged), the weight of the ice, and the weight of the bear. Solve for the weight of the bear, and thus determine the mass. Also, you can express the volume of the bear in terms of its specific gravity and its mass. So you'll have an "m" variable in two places, but still only one unknown and one equation, meaning you can still solve it.
thnx for ur explanation, but the answer I got using ur method is the same as I got before (592.9 kg), which is inconsistent with the 790 kg answer listed on the back of the book.
Perhaps you should show your work, and make sure your units are correct.
  • · Replies 16 ·
21K
