Finding & Deleting Hidden Files in MS Win XP Home Ed.
  • Thread starter Thread starter honestrosewater
    Home
The discussion revolves around the issue of locating and deleting hidden files within the "C:\WINDOWS\Downloaded Program Files" directory on a Windows XP Home Edition computer. Participants explore the visibility of files and folders, the implications of deleting certain files, and the use of command line tools to investigate file contents.
  • One participant notes that the Properties window indicates 60 files and 5 folders, while only 15 files are visible in Explorer, raising questions about the missing files.
  • Another participant suggests that the original installation CD may contain hidden files on the hard drive, which could explain the discrepancy.
  • Some participants mention that the folder may contain programs that aggregate multiple files, complicating the understanding of what is actually present.
  • A suggestion is made to use the command line to check the directory contents, which may provide a more accurate count of files than the Explorer view.
  • Concerns are raised about the potential consequences of deleting files from the folder, with warnings that it could lead to software malfunction or the need to reinstall the operating system.
  • One participant expresses suspicion about the presence of malware, specifically mentioning a file named "sahagent.exe" as a concern.
  • Another participant provides a link to a website that labels "sahagent.exe" as malicious, indicating a potential security risk.
  • There is confusion regarding accessing the "Downloaded Program Files" folder via the command prompt, with participants discussing the limitations of the command line interface.
Participants express varying opinions on the nature of the files in the folder and the risks associated with deleting them. There is no consensus on the best approach to handle the situation, and multiple competing views remain regarding the visibility and safety of the files.
Participants mention limitations in file visibility due to potential hidden attributes and the complexity of program files that may not be accurately represented in the folder properties. The discussion also reflects uncertainty about the implications of deleting files from the folder.
Users dealing with file management issues in Windows XP, particularly those concerned about hidden files, malware, and the implications of deleting system files.
honestrosewater
I am trying to clean out this computer. BTW it's my mom's so recommending a switch from XP has already been noted ;)
has crap in it that I want to delete. Its Properties window says it contains 60 files and 5 folders. However, only 15 files (and no folders) are shown in Explorer. What's the deal?
I have tried searching specifically for the files I know are in there (which I want to delete), but the searches return nothing.
I already have it set to show hidden files and folders. I even switched it to show protected OS files, but that didn't work either.
So where are the 45 missing files? How can I get to them?
Computer science news on Phys.org
Does it have the original CD-ROM with windows XP on it?
It may be like my box I bought a while ago has winXP home edition but no CD-ROM with the sofware on it. If something goes wrong you have to buy again the software from MS. It has the software in hidden files on the HD.
Make sure you have a second drive and Ghost the first drive on the second drive; this way you don't lose the OS.
Go in Windows Explorer click on Help and find out how to turn the hidden folders on and off.
This way you can see the missing folders and files.
Hope this helps.
Regards,
Michael
Yes, I have the original CD.
I already have everything set to show hidden files and folders. I have been trying Help- but it is no help, as usual ;)
They don't even show up in a search- and I have the search set to search hidden files and folders.
But I know these files are there. For one thing, ScanPest has found 5 of them. And the Properties window itself says there are 60 files and 5 folders inside. Plus, the files that are shown add up to only about half of the size of the entire file. Something is amiss.
P.S. have IE version 6.0
That particular folder shows its contents in a rather strange way.
Each "file" is actually a program containing 1 or more files. Right click on the program and click on properties. Then check the dependency tab and you have the list of files that is being counted in the folders properties window. But even this isn't a true reflection, since some of these files may not be in this folder at all.
If you drop to the command window and go to the folder and type dir, you will come up with another number of files. I think this is probably the most accurate indication of how many files are there in that folder itself.
As for deleting these, not sure what might happen, I wouldn't do it.
Edit:
K that was what my XP box led me to believe. Just checked my 2k box and the dependencies is way more. One thing they had in common though was that the dir in the cmd window returned 1 less file than the folder properties window in explorer. Still I wouldn't delete anything there, once you start doing that you may end up having to reinstall anyway.
I tried doing the similar thing to further get an idea on what you're trying to accomplish. It sounds to me like you went to your Program Files folder and you right click on a program (folder) then choose properties and realized that it doesn't show all the folders.
Why would you want to delete them when they're fragmented parts of the program. Unless you're not using the program anymore, if you delete one of them then you won't be able to run it. You may lose everything and start from scratch.
And believe me reformatting your entire hard drive is about as interesting as a Congressional hearing on farm subsidies.
Professional,
I am right-clicking on the DPF folder itself, and then on "Properties". Today it says the folder contains 60 files and 7 folders.
When I open the DPF folder, only 15 entries appear. It lists, among other things, the "status" of each entry (Installed, Unplugged, Unknown). I know what most of these are; one is Musicnotes- for sheet music, etc.
Yes, I know not to delete anything until I am certain I know what it is. I should have said "files that I *might* want to delete" ;)
My problem is that I cannot get to the files that I believe are there- malware- and the fact that I can't get to them makes me more suspicious. One of the files is C:\WINDOWS\Downloaded Program Files\sahagent.exe
Ah, thanks, I have done this and the files I'm looking for are not listed in this way either.
Command window?? Do you mean open a DOS prompt? Er... whatever it's called.
Thanks again :)
Rachel
http://www.liutilities.com/products/wintaskspro/processlibrary/sahagent/
bad nasty evil!
:P
As for the command window. Yes DOS prompt. Start/run cmd
will bring up the good old dos window. :)
Yes, I also have CoolWWWSearch :devil:
It's been a while since I worked in DOS (I think I was ~10). After a few failed attempts at guessing, I just did this
C:\WINDOWS>dir
but it doesn't list the Downloaded Program Files folder! :cry: It lists all the other folders except the one I want! What the #?$% is going on?
Okay, :smile: is there another way I can get to DPF in DOS? It *is* in C:\WINDOWS.
  • · Replies 24 ·
11K
  • · Replies 37 ·
  • · Replies 30 ·
13K
49K
