Register to reply
Force of Flowing Water
by smprindi
Tags: flow, force, velocity, water
Share this thread:
smprindi
#1
Jan15-09, 04:29 PM
P: 1
If a pipe flowing with water enters a structure where the structure wall will stop the horizontal velocity of the flow and direct it downward (i.e a pipe in to a manhole with an outlet at a considerably lower elevation), how do you calculate the force exerted on the structure of that wall. I have found the equation Force = density of water * flow volume * change in velocity. Is this on the right track?
Phys.Org News Partner Physics news on Phys.org
Physical constant is constant even in strong gravitational fields
Physicists provide new insights into the world of quantum materials
Nuclear spins control current in plastic LED: Step toward quantum computing, spintronic memory, better displays
tiny-tim
#2
Jan15-09, 05:15 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Hi smprindi ! Welcome to PF!
Quote Quote by smprindi View Post
… how do you calculate the force exerted on the structure of that wall. I have found the equation Force = density of water * flow volume * change in velocity. Is this on the right track?
Yes …
from good ol' Newton's second law …
force = rate of change of momentum
= velocity times mass per time …
which is the same as your Force = density of water * flow volume * change in velocity.
Register to reply
Related Discussions
Speed of Water Flowing Introductory Physics Homework 3
Water Flowing From a Tank Introductory Physics Homework 1
Water flowing out of a pipe Calculus & Beyond Homework 4
Water flowing in a pipe Introductory Physics Homework 6
PH, free charge, and flowing water Electrical Engineering 11
