Calculating Post-Collision Speeds of Billiard Balls
  • Context: Undergrad
  • Thread starter Thread starter pupatel
    Balls Collison
The discussion revolves around calculating the post-collision speeds of two billiard balls of equal mass undergoing a perfectly elastic head-on collision. Participants explore various equations and reasoning related to conservation of momentum and energy to determine the final speeds of the balls after the collision.
  • One participant presents the initial speeds of the balls (2.00 m/s and 3.00 m/s) and asks for help in determining their speeds after the collision.
  • Another participant claims that the speeds after the collision will be 3 m/s for the first ball and 2 m/s for the second ball, providing equations related to conservation of momentum and energy.
  • A participant expresses confusion regarding the equations used and states that they do not yield the correct answer.
  • Another participant reiterates the initial problem and suggests that the balls will interchange speeds, stating that Ball 1 will be at -3 m/s and Ball 2 will be at 2 m/s after the collision, and provides a derivation to support this claim.
  • A later reply acknowledges the previous answer and expresses a realization that there was a simpler method to arrive at the conclusion.
Participants present differing views on the final speeds of the billiard balls, with some asserting that they interchange speeds while others propose different outcomes based on their calculations. The discussion remains unresolved with multiple competing views.
Some participants reference conservation laws and provide derivations, but there is uncertainty regarding the correctness of the approaches and results. The discussion includes various mathematical steps that may depend on specific assumptions or interpretations of the problem.
pupatel
:confused:
I was wondering if someone can help me with this problem:
Two biilard balls of equal mass undergo a perfectly elastic head-on collison. If the speed of one ball was initially 2.00 m/s and of the other 3.00 m/s in the opposite direction, what will be their speeds after the collision??
See this:
http://hyperphysics.phy-astr.gsu.edu/hbase/colsta.html#c2
In short - the speed of the first ball would be 3 m/s and the speed of the second ball would be 2 m/s.
Conservation of momentum:
[tex]m_1v_1 + m_2v_2 = m_1u_1 + m_2u_2[/tex]
[tex]m_1 = m_2[/tex]
[tex]v_1 + v_2 = u_1 + u_2[/tex]
[tex](v_1 + v_2)^2 = (u_1 + u_2)^2[/tex]
[tex]v_1^2 + 2v_1v_2 + v_2^2 = u_1^2 + 2u_1u_2 + u_2^2[/tex]
Conservation of energy:
[tex]\frac{1}{2}m_1v_1^2 + \frac{1}{2}m_2v_2^2 = \frac{1}{2}m_1u_1^2 + \frac{1}{2}m_2u_2^2[/tex]
[tex]v_1^2 + v_2^2 = u_1^2 + u_2^2[/tex]
So we have:
Substract them:
[tex]2v_1v_2 = 2u_1u_2[/tex]
[tex]u_1 = \frac{v_1v_2}{u_2} = v_1 + v_2 - u_2[/tex]
[tex]u_1 = v_1v_2 = v_1u_2 + v_2u_2 - u_2^2[/tex]
[tex]u_2^2 - (v_1 + v_2)u_2 + v_1v_2 = 0[/tex]
A quick inspection would reveal that the solutions to that are v1 and v2. v2 is the speed before collision, so we are left with v1. Hence u1 = v2 and u2 = v1. There are probably much easier ways to come to this but it's late. :zzz:
I am still confused...I use these equations but it doesn't give me the right answer...
pupatel said:
:confused:
They will interchange speeds. Ball 1 was at 2m/s, after collision is -3m/s. Ball 2 was at -3m/s, after collision is 2m/s.
Edit: I notice Chen already gave this answer. Here's another derivation:
[tex]v_1+v_2=u_1+u_2\mbox{ and }v_1^2+v_2^2=u_1^2+u_2^2[/tex]
Move them around a bit:
[tex]v_1-u_1=u_2-v_2\mbox{ and }v_1^2-u_1^2=u_2^2-v_2^2[/tex]
Divide these last two equations and get:
[tex]v_1+u_1=v_2+u_2[/tex]
Subtract this from the first equation and also add it to the first equation, get:
[tex]v_2=u_1\mbox{ and }v_1=u_2[/tex]
I knew there was an easier way to get to that. :-p
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 53 ·
  • · Replies 49 ·
  • · Replies 45 ·
