Wavepacket Problem: Writing |psi(x,t)|^2
  • Thread starter Thread starter trash057
    Wavepacket
The discussion revolves around expressing the square of a wavepacket, |psi(x,t)|^2, as a linear combination of two eigenstates, phi0(x) and phi1(x). Participants are exploring the mathematical formulation and implications of this expression within the context of quantum mechanics.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss the initial formulation of the wavepacket and the subsequent expansion of the integral involving the wavefunctions. There is uncertainty about whether to expand the expression or simply write it down as requested.
Some participants have provided insights into the structure of the expression and the normalization of the wavefunctions. There is an ongoing exploration of how to handle the terms resulting from the expansion, with no clear consensus on the next steps or final formulation.
Participants mention the assumption that the wavefunctions are normalized and express concerns about handling symbolic representations versus numerical values. There is also a note about the nature of the coefficients involved in the linear combination.
trash057
A wavepacket, psi(x,t), can be expressed as a linear combination of eigenstates. Assuming that only 2 eigenstates, phi0(x) and phi1(x), contribute to the linear combination write down the expression for |psi(x,t)|^2.
[Boltzmann's constant = 1.38 x10^23 J /K, Planck's constant h = 6.626 x10 ^-34 J s,
Gas constant R = 8.314 J K /mol]
I need help with how to start solving this problem.
This is just an educated guess, but I'd say something like:
[tex]\psi = a_0 \psi_0 + a_1 \psi_1[/tex]
So:
[tex]\int \psi \psi^{*} d^3r = \int (a_0 \psi_0 + a_1 \psi_1)(a^{*}_0 \psi^{*}_0 + a^{*}_1 \psi^{*}_1) d^3r[/tex]
Now all you need to do is expand the RHS and see what you get (the integral is over all space, so what does that tell you about what the integral must equal?). If I were you I would also assume that the orginal wavefunctions (psi0 and psi1) are normalised, and that the constants a0 and a1 have no imaginary component.
That's what I would do for this question anyway, but I'm definitely no expert on the subject. lol.
So:
The integral must equal 1. But do I need to expand the RHS? It just says to write the expression not to evaluate the expression.
oh yeah, my bad.
Hey, no problem. Thanks for your help. I'm not sure how to expand this. I can handle numbers but when symbols are used, I start to have trouble. I'm guessing there will be four results, two zeroes and two ones. The ones being psi1 x psi1*, and psi0 x psi0*, but I'm not sure how to expand this and get those results.
Unless I made a mistake, you should end up with something like:
[tex]|\psi|^2 = |a_0 \psi_0|^2 + |a_1 \psi_1|^2 + a_0a^{*}_1\psi_0\psi^{*}_1 + a_1a^{*}_0\psi_1\psi^{*}_0[/tex]
Obviously the normalisation constants of the first two terms of that expression are going to be real. You can prove that by writing the normalisation constants as a complex exponential [itex]a_0 = r_0e^{i\theta_0}[/itex]. If you do that with a1 aswell, then you could simplify the other terms involving a1*a0 and a0*a1.
  • · Replies 131 ·
11K
