EM Wave Amplitude: Questions & Answers
The discussion revolves around the amplitude of electromagnetic (EM) waves, particularly in relation to their wavelength and the validity of using the linear wave equation for light waves. Participants explore the implications of amplitude measurements, field gradients, and the relationship between amplitude and wavelength in both classical and quantum contexts.
  • Some participants propose that the amplitude of a light wave is related to its wavelength, suggesting that large amplitudes could invalidate the linear wave equation due to large displacement gradients.
  • Others clarify that amplitude and wavelength are fundamentally different quantities, with amplitude measured in volts per meter or tesla, while wavelength is measured in meters.
  • A participant questions the validity of using the linear wave equation for EM waves, seeking clarification on the implications of amplitude and field gradients.
  • There is a discussion about the "width" of the wave in relation to the source aperture and diffraction effects, noting that the width is not directly connected to wavelength unless diffraction becomes significant.
  • One participant emphasizes that photons do not have a defined size in the context of quantum electrodynamics (QED), which complicates the discussion of amplitude in relation to individual photons.
  • Another participant provides the differential wave equation as a reference for the linear nature of the equations governing EM waves, highlighting their derivation from Maxwell's Equations.
Participants express differing views on the relationship between amplitude and wavelength, with some asserting they are distinct quantities while others explore their potential connections. The validity of the linear wave equation remains a point of contention, with no consensus reached on its applicability to EM waves with large amplitudes.
Participants note that the discussion involves assumptions about the nature of amplitude and its relationship to wavelength, as well as the implications of using linear wave equations under certain conditions. There is also a lack of clarity regarding the role of field gradients in this context.
Emreth
Hi
I hope this is the right place to post.
I have some questions regarding EM wave amplitudes. There are some other posts in the past regarding this and some people replied by saying that amplitude of a light wave is equal/close to wavelength of the wave. This is deduced from the fact that light wave with a certain wavelength does not pass through holes smaller than the wavelength, so the amplitude should be somewhat near. If this is even approximately true, then linear wave equation should not be valid for light waves since its derivation assumes small displacements/gradients in the transverse direction. For large amplitudes relative to wavelength, the displacement gradient can reach large values.
Of course i must be missing something here, E0 and B0 do not have length units, or do they?
Any ideas?
Ok I have to rephrase this because its wrong the way I put it. There's no transverse displacement, but rather extent of E and B fields.
Let me say, E field gradient gets large or not?Prob not i presume if E0 is really small. Is that the case?Although the spatial extent of the field is comparable to wavelength, the actual field gradient is very small.Is that it?
Wavelength is measured in units of length (meters, etc.). The amplitude of an electromagnetic wave is measured either in volts per meter if you're looking at the electric part of the wave, or in tesla if you're looking at the magnetic part. Either way, the amplitude is a completely different type of quantity from the wavelength, and it makes about as much sense to compare their sizes as it makes sense to compare the size of a color and an odor.
Bingo! :biggrin:
ehe i corrected that before you posted, beat you by 3 mins
Yeah, now I see what you posted. That sort of thing happens a lot around here.
So now you're thinking of the "width" of the wave in terms of the amplitude (as measured in appropriate units) falling off as you go away from the centerline or axis of the wave? In that case, from a classical point of view, that's basically determined by the source of the wave (size of the aperture in the source). It isn't connected with the wavelength except if you make the aperture small enough that diffraction effects become important. When you get to that point, the "width" of the beam spreads out over an angular range corresponding to the first minimum in the diffraction pattern.
If you're thinking of single photons, I don't think it's meaningful to consider photons as having a particular size, either along the direction of propagation or transverse to it. Photons are quanta of energy of the electromagnetic radiation field, and position doesn't enter into their description in QED (or so I understand from postings by others who know more about QED than I do).
No I'm not interested in photons. What I'm wandering is if its really valid to use the linear wave equation?
Anybody?
What do you mean by "linear wave equation?" If you mean the differential wave equation
[tex]\nabla^2 \vec E = \frac{1}{c^2} \frac{\partial^2 \vec E}{\partial t^2}[/tex]
and the identical equation for [itex]\vec B[/itex], they can be derived from Maxwell's Equations, as was first done by Maxwell himself.
These are linear differential equations whose solutions obey the principle of superposition.
  • · Replies 21 ·
  • · Replies 24 ·
16K
