| Thread Closed |
Beer-Lambert equation |
Share Thread | Thread Tools |
| Jan19-09, 02:45 PM | #1 |
I need to use the Lambert-Beer equation to plot optical density of a lactate solution. 2. Relevant equations [tex]A=\varepsilon\ell C[/tex] (The path length is 1 cm) 3. The attempt at a solution This is one of my four samples (if you can show me where I'm going wrong with this then I can apply the correction to the others): 2.22 [tex]\mu[/tex]mol in 1.5ml, therefore there is 0.296 [tex]\mu[/tex]mol in 0.2ml This info seems to match to the example graph I have. But using the formula above, where [tex]\varepsilon[/tex]=6.22 for micromol/ml, I get: 6.22 x (0.296/0.2) micromol/ml = 9.2056 This doesn't match up with the graph I have! Any help appreciated! Please!
| Jan19-09, 03:54 PM | #2 |
Recognitions:
Beer's law is accurate only for values of A from about 0.1 to 1.0. Experimentally, it is difficult to accurately measure absorption values outside this range.
| Jan19-09, 05:50 PM | #3 |
That's the main problem, the results from the example graph are at a maximum of 0.4 for the absorption at 340nm (y-axis) when plotted against amount in micromoles up to 0.4 on the x-axis.
I can get a fairly close approximation (the graph itself is supposed to be an estimate) if I use the following formula: (amount in micromoles x amount in ml) x 6.22. But this equation makes no sense; or at least I can't see the reasoning behind it. |
| Jan19-09, 09:28 PM | #4 |
Recognitions:
The slope of the best fit line to the graph should give you ε.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Beer-Lambert equation
| Beer-Lambert law | Quantum Physics | 4 | ||
| Beer-Lambert law question | Atomic, Solid State, Comp. Physics | 2 | ||
| Beer-Lambert Law question | Chemistry | 4 | ||
| beer lambert equation and concentration | Biology, Chemistry & Other Homework | 1 | ||
| Beer-Lambert Law | Chemistry | 6 | ||
