Solving a system of linear equations
The system of linear equations presented is defined by the equations 2x - z = 4, x - 2y + 2z = 7, and 3x + 2y = 1. The analysis confirms that this system has a unique solution: x = 2, y = -5/2, and z = 0. The discussion clarifies that the term "describe parametrically" refers to cases with multiple solutions, which is not applicable here since only one solution exists.
  • Understanding of linear algebra concepts, specifically systems of equations.
  • Familiarity with solving linear equations using substitution or elimination methods.
  • Knowledge of parametric equations and their applications in linear systems.
  • Basic skills in mathematical notation and terminology.
  • Study methods for solving systems of linear equations, including Gaussian elimination.
  • Learn about parametric representations of solutions in cases of infinite solutions.
  • Explore the implications of unique versus multiple solutions in linear algebra.
  • Practice solving various systems of equations to reinforce understanding.
Students studying linear algebra, educators teaching systems of equations, and anyone seeking to enhance their problem-solving skills in mathematics.
fluidistic
Find out if the following system of equation has solution. In case of having solutions, describe parametrically them all and give 2 of them explicitly.
2x-z=4
x-2y+2z=7
3x+2y=1
2. The attempt at a solution
I don't see nowhere in my notes what they want by "describe parametrically".
Anyway I've solved the system and it has only one solution : x=2, y=-5/2 and z=0.
As I just typed them, it is the explicit solution... I don't see how I could give 2 of them if there is only 1 solution. And much less parametrically.
Do you know what they mean?
2x-z=4
x-2y+2z=7
3x+2y=1
Your answer is the same as I got. I believe that the problem was asking was that if there were multiple solutions (which would then depend on one or two parameters), you should give two specific solutions. In this case, there is only one solution, and you have given it, so you're done.
Ah ok! This is quite possible because there was more than one system of equations to solve.
Thank you.
  • · Replies 30 ·
  • · Replies 28 ·
