Point on a Curve: Solving Related Rates Problems
  • Thread starter Thread starter jgens
    Curve Point
The problem involves a particle moving along a curve defined by the equation y = 4 - x^2, with the goal of determining the point where the rates of change of x and y are equal.
  • Exploratory, Assumption checking
  • Participants discuss the relationship between the rates of change of x and y, with one suggesting that x' = y' and exploring the implications of this assumption. Others question the necessity of assuming an external parameter for the rates of change.
The discussion is ongoing, with various interpretations being explored. Some participants express confidence in the original poster's approach, while others raise concerns about potential assumptions that could lead to incorrect conclusions.
There is a mention of the derivative y'(x) and its relationship to the rates of change, indicating that the discussion may involve clarifying the definitions and implications of derivatives in the context of related rates.
jgens
A particle moves along a path described by y = 4 - x^2. At what point along the curve are x and y changing at the same rate
Simple equations regarding derivatives.
It's been a while before I've done any related rates problems, could someone please let me know if this is correct:
Since, x and y must be changing at the same rate (presumably with respect to time) x' = y' and y' = -2xx'. Therefore, -2x = 1 and x = -1/2. Placing my x value into the original equation yields 15/4. Hence, the point is (-1/2, 15/4).
Thanks.
SEEMS correct...
Of course, it's right. What could go wrong?
Plenty, I could have made an incorrect assumption ultimately leading to false conclusions.
Good answer but you do not need to assume that x and y are varying wrt an external parameter. The derivative y'(x) = dy/dx of y wrt x expresses the instantaneous rate of change of y wrt a change in x.
The points where y and x are changing at the same rate are those where y'(x)=1.
  • · Replies 27 ·
