How Does Banking Angle Affect the Radius of an Airplane's Turn?
The discussion revolves around the physics of an airplane's turn, specifically how the banking angle affects the radius of the turn. The original poster describes a scenario involving a plane circling an airport at a specific speed and altitude, while maintaining a bank angle.
  • The original poster attempts to calculate the distance from the airport using forces acting on the airplane, including lift and gravity, and expresses uncertainty about the simplicity of their solution. Other participants question the assumptions made regarding the lift force and suggest reevaluating the approach to find the radius of the turn.
The discussion is ongoing, with participants providing feedback and alternative perspectives on the calculations. There is a recognition of potential errors in the original poster's reasoning, particularly regarding the lift force, and suggestions for a more accurate approach have been made.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made. The original poster's calculations have evolved through the discussion, indicating a process of refinement and exploration.
mcgooskie
In this problem I need to figure out how far I am from the airport.
The pilot tells us that we have to circle the aiport before we can land. We will maintain a speed of 450mph at an altitude of 20,000ft. while traveling in a horizontal circle around the airport. I notice that the pilot banks the plane so that the wings are oriented at 10deg to the horizontal. An article in the in-flight magazine says that planes can fly because the air exerts a force "lift" on the wings which is perpendicular to the wing surface.
So:
V=660 ft/s
h=20,000 ft
bank = 10deg to the horizontal
So I drew a FBD with my normal force perpendicular to my wings, which were banked to the horizontal.
Sum Fx=Wx=ma where a=v^2/r
sin10 (mg)=mv^2/r (mass drops out)
sin10 (32.2ft/s^2)=(660ft/s)/r
solving for r=118.03ft
add that to the current altitude of 20,000ft gives a distance of 20,118ft from the airport?
It doesn't seem like this problem could be this "easy". I feel like I am totally missing a point here.
Thanks!
oops! I forgot to square my velocity. That being said, I have a new r=77,904ft.
If you figure 77,904 as the x value of a right triangle, and 20,000 as the y value, then the hypotenuse or distance from the airport would be 80,431ft or approx 15miles. This sounds more reasonable?
Why have you taken "mg" as your lift force?
Take another look!
It seems from what you wrote above, the force F that is giving the plane lift has magnitude of mg. This is clearly not true.
Using F = ma in the vertical direction gives
[tex]0 = Fcos(\theta) - mg \rightarrow F = mg/cos(\theta)[/tex]​
where [tex]\theta[/tex] is the bank angle.
Plug this F back into what you have above, solve for r, use the pythagorean theorem and you're done.
e(ho0n3
11K
14K
29K
15K
