Elastic collision between an unknown mass and an alpha particle
The discussion revolves around an elastic collision involving an alpha particle and an unknown nucleus at rest. The alpha particle is deflected at a right angle and experiences a loss of 40 percent of its energy. Participants are tasked with identifying the unknown nucleus based on these conditions.
  • Participants explore the relationship between the deflected angle and the recoil angle, questioning how to apply the given energy loss to find the unknown mass. There is also confusion regarding the interpretation of the angle φ and its implications for determining the unknown mass.
Some participants have offered clarifications regarding the definitions of angles involved in the collision and the implications of energy loss. Multiple interpretations of the angles and energy relationships are being explored, indicating an ongoing examination of the problem.
Participants are navigating assumptions about the definitions of angles in the context of elastic collisions and the implications of energy conservation principles. There is a noted confusion regarding the correct interpretation of the energy loss percentage and its relationship to the angles involved.
pentazoid
In an elastic collision between an alpha particle and an unknown nucleus at rest, the alpha particle was deflected through a right angle and lost 40 percent of its energy . Identify the mysterious nucleus.
(E2)/(E0)=[4*gamma/(gamma+1)^2]*(sin(phi/2))^2
[tex]\theta[/tex]2=.5*(pi-phi)
gamma is the ratio between the alpha mass particle and the unknown mass
Is the deflected angle the recoil angle? If so then I can use the recoil angle to find phi. Then I can use phi to find gamma and with gamma since I know the mass of an alpha particle, I can find the unknown mass. When the problem says the recoil angle loses 40 % of its energy , doesn't that mean E2=.4E0
Hi pentazoid! :smile:
Yes, the deflected angle is the recoil angle …
but no, E2=.6E0 :wink:
if my deflected angle is 90 degrees that means my phi is zero. which means sin(phi/2) is zero, which means then that there is no way to determine what the unknown mass is
I'm confused :confused:
isn't φ = π/2?
Not if you mean the angle that the nucleas recoils. Conservation of energy and momentum determine this recoil angle.
  • · Replies 41 ·
