Hydrostatics/Equilibrium: An object hanging by a light cord in a bucket of water
  • Thread starter Thread starter LunarJK
    Light Water
The discussion centers on calculating the volume of a rock with a mass of 2.8 kg suspended in a bucket of water within a stationary elevator. The tension in the cord is measured at 19.9 N. The participant initially applies the principles of fluid dynamics, including Pascal's Law and equilibrium equations, but is advised to utilize Archimedes' Principle for a more straightforward solution. The correct approach involves recognizing the buoyant force acting on the rock and applying the formula V = m/ρ to determine the volume.
  • Understanding of Archimedes' Principle
  • Knowledge of fluid dynamics concepts
  • Familiarity with equilibrium equations
  • Basic skills in physics calculations involving mass and density
  • Study Archimedes' Principle in detail
  • Learn how to apply fluid dynamics equations in practical scenarios
  • Explore the relationship between buoyancy and volume calculation
  • Review equilibrium conditions in static fluids
Students studying physics, particularly those focusing on fluid dynamics and equilibrium, as well as educators seeking to clarify concepts related to buoyancy and volume calculations in fluids.
LunarJK
A rock with a mass of 2.8 kg is suspended from the roof of an elevator by a light cord. The rock is totally immersed in a bucket of water that sits on the floor of the elevator, but the rock doesn't touch the bottom or sides of the bucket.
When the elevator is at rest the tension of the cord is 19.9 N. Calculate the volume of the rock in cubic centimeters (cm^3).
Pascal's Law: P = Po + gρh
V = Ah or V = m/ρ
P = F/A
ΣF = 0
I am a little confused about how to go about this problem as I'm just starting into fluid dynamics... but my initial step into this was to assume that if the rock is not touching the bottom of the bucket, and is also not floating up, that it is in a state of equilibrium.
So I started by trying to recognize all forces acting upon the rock: T-tension on the cord upwards, mg-weight of the rock due to gravity, PoA- force of the Atmospheric pressure acting down on the rock, and PA-pressure of the water acting up on it. From this i stated that:
T + PA - mg - PoA = 0 thus,
T + PA = mg - PoA
However since i know the mass of the rock, tension of the cord, and I'm assuming gravity to be 9.81 m/s2, this equation can be simplified as far as:
A(P-Po) = 7.56N
Now the Po will equal just the standard atmospheric pressure of 101.345 kPa, but that still leaves 2 unknowns that I'm not too sure how to deal with.
Since i am looking for Volume of the rock, i can relate volume in only two equations i can think of, which are V = Ah, and V = m/density. Since I am already working with a formula that involves the area, I am thinking my next step would be to somehow use pascal's law to find the depth the rock is submerged into find the volume at the end?
Anyways, any tips would be nice. Let me know if I'm on the right track, or if I'm way overlooking a simpler solution.
You have to use Archimedes' Principle, not Pascacl's law.
  • · Replies 19 ·
