Interactions Between Sedimentary, Igneous, and Tectonic Cycles
  • Thread starter Thread starter Pattielli
    Cycles Pair
The discussion focuses on the interactions between various geological cycles, specifically sedimentary, igneous, and tectonic cycles, as well as the water cycle. Participants seek to understand how these cycles influence one another and contribute to geological processes.
  • Exploratory, Conceptual clarification
  • One participant notes that the rock cycle, which includes weathering, erosion, transportation, and sedimentation, is dependent on the hydrologic cycle and interacts with the plate tectonic cycle.
  • Another participant mentions that the plate tectonic cycle is driven by Earth's internal heat and results in the recycling of material through the mantle and back into the crust.
  • A specific example is provided regarding the interaction between the water cycle and tectonic cycle, highlighting that the uplift of the Himalayas creates steeper gradients that lead to sedimentation downstream.
Participants express varying levels of understanding and seek clarification, indicating that the discussion is exploratory and not yet resolved. There are no clear agreements or disagreements presented.
Some assumptions about the definitions and interactions of the cycles may be implicit, and the discussion does not resolve the complexities of these interactions.
Individuals interested in geology, earth sciences, or environmental studies may find this discussion relevant.
Pattielli
The water and sedimentary cycles are interrelated in many ways, Would you please help me to identify the interactions between :
sedimentary and tectonic, sedimentary and igneous, igneous and tectonic, water and tectonic ?
Thank you very much in advance,
Help me please...True, I really need your help on these things...
Okay, for starters some loose remarks.
the rock cycle of weathering,erosion, transportation, sedimentation is dependent on the hydrologic (water) cycle, and also interacts with the plate tectonic cycle. The plate tectonic cycle is driven by earth’s internal heat and results in the slow but continuous recycling of material through the mantle and back up into the crust
Water cycle - tectonic cycle - sedimentary cycle interaction:
The uplift of the Himalyas causes steeper gradient that leads to sedimentation of floods downstream.
Yes, I have just started to learn about Earth since last week...
Thank you , Andre very much for your explanation and those usefull links, <:sm:>
  • · Replies 0 ·
10K
High School CNO Cycle
