Building Devices for College Admissions: Advice and Safety Precautions
  • Thread starter Thread starter stringssssss
    Build
The discussion revolves around the idea of building devices to enhance college admissions prospects, particularly in the context of physics and engineering. Participants explore various project ideas, safety considerations, and the educational value of different experiments.
  • Experimental/applied
  • One participant expresses a desire to build a device, such as a particle beam, to improve their college application, despite limited experience in advanced mathematics and physics.
  • Another participant warns against building a particle accelerator due to safety concerns and suggests considering other projects instead.
  • A suggestion is made to recreate a historic physics experiment, like JJ Thomson's cathode-ray tube experiments, which could be done simply and cheaply while still providing valuable learning experiences.
  • Some participants discuss the potential dangers of working with cathode-ray tubes (CRTs) and emphasize the importance of safety, particularly for those with no lab experience.
  • There is mention of available kits for experiments like Rutherford scattering, which could impress undergraduate physics departments if improved upon.
  • Concerns are raised about the safety of certain setups, particularly regarding exposed components that could pose risks of electric shock.
Participants generally agree on the value of building projects to enhance college applications, but there is disagreement regarding the safety and appropriateness of specific experiments, particularly those involving CRTs and particle accelerators. The discussion remains unresolved on which projects are most suitable for someone with limited experience.
Participants express varying levels of concern regarding safety and feasibility, particularly in relation to the complexity and risks associated with certain experiments. There is also a lack of consensus on the best type of project to undertake given the participant's skill level.
stringssssss
I need to build something!
hi, i know that if you can make certian devices, it can increase your chance at getting in a great school. i only know calculus (some differential) and basic calculus based physics, however i lean ultra fast (so if its i little bit over my head, i can figure it out with the help of the net and my books). i understand the theory upper dvision classes, but some of the math is a little musch. any way i would like some advice on what type of device to build? for example a particle beam. i know some of you are probibly thinking this kid has no idea what he's talking about, but please bear with me. i am smarter than this post might lead you to believe. if anyone has any advice on something to build to help me gent into a great school within my skill range (with varying degrees of freedom, if your not sure just suggest it anyway) . Thank you
Welcome to the PF.
We've discussed particle accelerator construction here on the PF before, and it's generally too dangerous for most home-project folks. You can do a PF search to read some of those threads.
I think using a project to enhance your college application is a fine idea. Are you in undergrad now, looking ahead to grad school, or are you looking to apply to enter college?
Have you done any Science Fair projects? What did you do? What degree are you looking to earn in college? (Like EE, ME, Math, Physics, etc?)
BTW, be sure to proofread your college applications and essays a bit better than you proofread your first post above. Not giving you too bad of a time about it, but writing well will also help you get into a good school.
hi berkeman, yes I am an undergrad right now. I am going to apply to berkeley and standford next year. I have not done any science fairs or engineering fairs, mainly because i haven't had the time. I have considered an accelerator, but the divergance fields look tricky, and its costly, but id love to build one. I am looking to earn a Math, and Physics degree. i want to work with theoretical physics (m-theory, quantum mechanics, anything tword unification of gravity). Thanks for your reply, by the way do you have anything to do with uc berkeley (i ask because of your name).
Naw... that's the net for you. His real last name is 'Los Angel'... 'Berk' is a pseudonym.
I would recommend recreating a historic physics experiment and see how close you can get to the accepted value. You'll learn valuable lab skills, physics, and most can be done simply and cheaply without even calculus.
A particular experiment that comes to mind is JJ Thomson's cathode-ray tube experiments that get the mass/charge of an electron. I would guess you get even get a kit (as this is a common experiment to give students) and then work on improving its accuracy. If you can improve the accuracy it shows you really understand what you are doing and why.
As an added bonus it also uses a 'particle beam'. :)
They have all kinds of cool kits online, even Rutherford scattering. Wow!
https://www.fishersci.com/wps/portal/PRODUCTDETAIL?productId=696990&catalogId=29101&pos=17&catCode=SE_SC&fromCat=yes&keepSessionSearchOutPut=true&brCategoryId=56935&hlpi=false&fromSearch=
I would think that if you could improve the measurement made by one of these setups (and prove it!) that would impress most undergraduate physics departments. But keep in mind I'm also not on the admission committee. So what do I know.
Not sure we want him working with a CRT -- kinda' dangerous for a first experiment/project.
And Danger is correct, no Berkeley association... my undergrad was at UC Davis, and MSEE was back East in the snow. Brrr.
If by CRT you mean TV I totally agree. Even professionals should be weary of playing with high voltage devices. But there is nothing intrinsically dangerous about a CRT, especially if one uses a prefabbed student kit.
Edit:
After looking more closely at the setup it does seem the banana clips of the induction coil are exposed so there is risk of shock. I figured the students kits would be much more sealed and safegaurded. Not such a great experiment for someone with no lab experience.
11K
  • · Replies 58 ·
11K
  • · Replies 24 ·
  • · Replies 37 ·
