Register to reply
High Speed Photography Circuit
by noagname
Tags: circuit, photography, speed
Share this thread:
noagname
#1
Jan23-09, 04:17 AM
P: 136
I want to take high speed shots. My problem is I don't want to buy an expensive flash, so I thought let me make a sound activated shutter. In other words the moment their is a sound my camera takes a picture. After spending hours on the internet I was only able to find circuits that give me and output of 400 volts. Link 1 link 2 link 3 link 4 link 5
Yes I do know that all of those are meant for flashes but found a way to that output into my camera, I just can't have 400 volts coming out of their.
Phys.Org News Partner Engineering news on Phys.org
Greater safety and security at Europe's train stations
Fingerprints for freight items
On the way to a safe and secure smart home
brewnog
#2
Jan23-09, 09:54 AM
Sci Advisor
PF Gold
brewnog's Avatar
P: 2,793
What do you mean "high speed shots"? How many frames do you wish to capture per second? The reason it's often done with a flash is because normal cameras can't get anywhere near enough light in (using ambient sources) in the small duration required.
noagname
#3
Jan25-09, 11:10 AM
P: 136
I have a Nikon d80, and I should have made it more clear. I have an external light source with is strong enough for what I am doing, only problem is, is it not meant to be turned on and off at high speeds. "High speed shots" I just meant taking high speed photography, and I don't really care the amount of frames per second.
brewnog
#4
Jan25-09, 01:05 PM
Sci Advisor
PF Gold
brewnog's Avatar
P: 2,793
So you want to use the Nikon's shutter? Surely the Nikon has a remote shutter release input, which would just be a circuit to close?
noagname
#5
Jan25-09, 03:49 PM
P: 136
Yea, you are spot on. The jack on the camera is just a circuit, when to connect one side to the other the shutter goes off. I need to make it so the shutter goes off the moment it hears a sound. Only problem is, is in the 5 links that i gave they all have a giant voltage output.
Once I find a way to lower the voltage. I need to find a way to connect the circuit with the camera. Off of ebay I can get for 4-5$ a wire that goes into the camera.
es1
#6
Jan25-09, 07:41 PM
P: 324
It seems the third circuit you found should be perfect.
http://lullaby.homepage.dk/diy-camera/usoft.html
Just use a resistor instead of the MOC3020 part (or possibly put a resistor across terminals 6 and 4) to do the level translation. Assuming the voltage you need is below 9V, of course.
noagname
#7
Jan26-09, 11:15 AM
P: 136
How strong of a resistor and what does the moc3020 do?
es1
#8
Jan28-09, 12:36 AM
P: 324
maybe you can just use the circuit as is. what are the input requirements of your camera?
noagname
#9
Jan28-09, 05:25 AM
P: 136
voltage requirments, I have no clue. Like I said earlier the camera jack where I control the shutter has 4 pieces of metal, If I stick a wire in and touch wire A, B all to D then the camera goes off. If I touch a wire to just C and then to D the camera re focuses(which I don't care about.)
Register to reply
Related Discussions
High Pass Filter RL circuit: Time/Frequency Response Engineering, Comp Sci, & Technology Homework 0
High Voltage Circuit trouble Electrical Engineering 5
High speed winch Engineering Systems & Design 3
Collisions at high speed vs normal speed General Physics 5
Building a circuit? - easy high school project...sorta Introductory Physics Homework 1
