Can someone help me optimize my MATLAB code by vectorizing loops?
  • Context: MATLAB
  • Thread starter Thread starter dpsguy
    Loops Matlab
The discussion focuses on optimizing MATLAB code by vectorizing loops to enhance performance. The original code utilizes a for loop to modify a matrix based on random values, which can be replaced with logical indexing for efficiency. The suggested optimized code uses logical indexing to directly manipulate matrix elements, significantly improving execution speed. Users are encouraged to verify performance improvements using MATLAB's built-in profiling tools.
  • Familiarity with MATLAB programming language
  • Understanding of matrix operations in MATLAB
  • Knowledge of logical indexing techniques
  • Experience with performance profiling in MATLAB
  • Learn about MATLAB logical indexing and its applications
  • Explore MATLAB's profiler to analyze code performance
  • Investigate MATLAB's built-in functions for matrix manipulation
  • Research best practices for vectorization in MATLAB
MATLAB programmers, data scientists, and anyone looking to optimize their MATLAB code for better performance.
dpsguy
Could someone please tell me how to make the following code in MATLAB more efficient? I am particularly keen to remove the for loop, as I understand that vectorizing the loop makes the program run much faster.
R=rand(ret,len);
[i j]=find(R<pm);
N=horzcat(i,j);
for i=1:length(N)
X(N(i,1),N(i,2))=bitcmp(X(N(i,1),N(i,2)),1);
end
Here ret and len are positive integers and pm is a number between 0 and 1. X is a matrix of dimensions (ret x len) and is filled with 0s and 1s at random. Basically what this piece of code does is meant to do is generate a random number between 0 and 1 for each element of the matrix X and check if the generated number is less than pm. If it is, then it replaces that element in the matrix with its ones complement.
Any help would be appreciated.
You can use logical indexing:
Code:
R = rand(ret,len);
X(R<pm) = bitcmp(X(R<pm),1);
or equivalently since I don't think you need to use bitcmp,
Code:
R = rand(ret,len);
X(R<pm) = ~X(R<pm);
That overwrites the values of X that have the same indices of the desired values of R.
I'm not sure if that will appreciably speed up your code (you can check using tic and toc or using MATLAB's profiler). Logical indexing is faster, but I thought MATLAB accelerates its code nowadays so that for loops actually run as fast (provided they follow certain rules; check the mathworks website for code acceleration/optimization). Changing from calling bitcmp to just negating the value may speed things up a bit... but it may not since I think built-in functions run pretty fast... Hope that helps...
Thanks a lot jamesrc! Your suggestions improved the speed and also the look of the program.
10K
