Spring and electrostatic forces
The discussion centers on using a lightweight spring to measure electric charge through the application of Hooke's Law and Coulomb's Law. The spring, initially unstretched at 4.0 cm, stretches to 5.0 cm when a 1.0 g mass is hung from it, leading to the calculation of the spring constant (k) as 981 N/m. When charged beads are attached, the spring stretches to 4.5 cm, but initial calculations for charge yield non-real results due to errors in mass and gravitational force assumptions. Corrections include using a mass of 0.001 kg and adjusting gravitational acceleration to 9.81 m/s², which resolves the issue.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with Coulomb's Law for electric forces
  • Basic knowledge of unit conversions (grams to kilograms)
  • Ability to manipulate algebraic equations for solving physical problems
  • Review the derivation and applications of Hooke's Law
  • Study Coulomb's Law in detail, focusing on electric charge interactions
  • Practice unit conversions, especially between grams and kilograms
  • Explore the concept of electric field strength and its relation to charge
Students in physics, educators teaching mechanics and electromagnetism, and anyone interested in experimental physics involving springs and electrostatic forces.
Krique
You have a lightweight spring whose unstretched length is 4.0 cm. You're curious to see if you can use this spring to measure charge. First, you attach one end of the spring to the ceiling and hang a 1.0 g mass from it. This stretches the spring to a length of 5.0 cm. You then attach two small plastic beads to the opposite ends of the spring, lay the spring on a frictionless table, and give each plastic bead the same charge. This stretches the spring to a length of 4.5 cm.
When the spring is hanging from the ceiling, it has no acceleration. And since it is lightweight, I assume that the mass of the spring does not matter. The only forces acting on the spring while hanging are the weight of the block and the force of the spring, which should cancel out. So (mass)(gravity) = -kx. We are given that the unstretched length is 4 cm, so we know that x = .01 m. The mass is 1g, and gravity is always -9.81 m/s^2. We can then solve for k. I got 981 N/m.
Now that I have the spring constant, I solved for the charges. When it is on the table, the only forces acting on the spring in the horizontal direction are the charges and the spring, which cancel each other out. So K (Q1*Q2)/r^2 = -kx. In this case, x is .005 m and r is .045 m. k is the same as before, 981. Q1 is equal to Q2 because they have the same charge. I assume K to be 8.99*10^9 because that is what all of our homework assignments have been using.
Solving for Q1^2, I got -1.105*10^-12. This makes Q1 and Q2 non real answers. If I drop the negative, they are 1.05*10^-6 C, which is also incorrect. Any ideas where I am going wrong?
Krique: The mass is 0.001 kg, not 1. Try it again and see if this makes your answer correct. In both of your equations, change -k*x to k*x. And change g = -9.81 m/s^2 to 9.81 m/s^2. Your ke value in Coulomb's law is correct; ke = 8.9876e9 (N*m^2)/C^2.
Oh man, I feel dumb for missing that. Thanks :)
