Thread Closed
Reflection and Refraction, much index of refraction
Share Thread Thread Tools
Jan28-09, 12:06 PM   #1
1. The index of refraction for water is 1.33 and that of glass is 1.50.
a. What is the critical angle for a glass-water interface?
b. In which medium is the light ray incident for total internal reflection?
2. Relevant equations
nisin[tex]\vartheta[/tex]i=nrsin[tex]\vartheta[/tex]r
3. The attempt at a solution
a. I think the answer to a. is 62.46 degrees, but I am not sure.
b. I think the answer is glass, simply because it is going to be moving from a less dense area to a more dense area.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jan28-09, 12:46 PM   #2
Use Snell's law:
[tex]n_1\sin\theta_1 = n_2\sin\theta_2\ .[/tex]
Note: It's not additive like you suggested.
At the critical angle, [tex]\theta_2[/tex] is 90 degrees (the light refracts along the boundary). That is to say, it's sin is 1. We can therefore rearrange for the critical angle:
[tex]\theta_{\mathrm{crit}} = \sin^{-1} \left( \frac{n_2}{n_1} \right)[/tex]
Now we have two refractive indices, the glass and the water. If you plug them in incorrectly, you're going to end up with trying to find the inverse sin of a value > 1, which isn't possible as this has no solution.
Jan28-09, 12:59 PM   #3
Quote by astrorob View Post
Use Snell's law:
Quite sorry for the mistake in Snell's Law. I knew what it meant, I just messed up when writing it in the forum.
Anyway, I appreciate the input, but if you are using
[tex]\theta_{\mathrm{crit}} = \sin^{-1} \left( \frac{n_2}{n_1} \right)[/tex], would it not be possible to put 1.33 (n2) over 1.5 (n1)? This would look like
[tex]\theta_{\mathrm{crit}} = \sin^{-1} \left( \frac{1.33}{1.5} \right)[/tex] and if plugged into a calculator, would return 62.45732485 degrees.
Jan28-09, 01:05 PM   #4
For this problem I calculated 62.4 degrees, the same thing you got.
As for B, I put water.
Jan28-09, 01:08 PM   #5
Yes, that's correct as you've stated.
It also gives you the answer to your second question as [tex]n_2[/tex] represents the refractive index of the medium that the light travelling in medium [tex]n_1[/tex] is incident on.
Jan28-09, 01:08 PM   #6
Quote by patriots1049 View Post
Ah, thank you. I was actually thinking that it would be glass because my book details the fact that "Total internal reflection occurs when light passes from a more optically dense medium to a less optically dense medium at an angle so great that there is no refracted ray." This would mean that glass-water would be a more optically dense to a less optically dense scenario.
Jan28-09, 01:10 PM   #7
Thank you very much. You have been a big help today, astrorob.
Thread Closed
Thread Tools
Similar Threads for: Reflection and Refraction, much index of refraction
Thread Forum Replies
Index of Refraction Introductory Physics Homework 7
index of refraction when total internal reflection ceases Introductory Physics Homework 4
index of refraction Introductory Physics Homework 3
Index of refraction Introductory Physics Homework 4
Reflection,Refraction,Total Internal Reflection,Diffraction Introductory Physics Homework 2
