Finding the Gradient and Solving for Zero Points on a Cubic Curve
The discussion revolves around finding the gradient of a cubic curve defined by the equation y = 2x³ - 5x² + 46x + 87, specifically at the points where it crosses the x-axis, and demonstrating that there are no points on the curve where the gradient is zero.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the derivative of the function and its implications for finding points where the gradient is zero. Questions arise about the relationship between the two parts of the problem and whether further differentiation is necessary. There is also exploration of the nature of the roots obtained from the quadratic equation derived from the derivative.
Some participants have provided guidance on setting the derivative equal to zero to find potential x values, while others are clarifying the implications of complex roots in relation to the curve's behavior with respect to the x-axis. The discussion is ongoing, with multiple interpretations being explored.
There is a focus on understanding the implications of complex roots and their relation to the curve's intersection with the x-axis, as well as the requirement to show that no real solutions exist for the gradient being zero.
maobadi
1. Calculate the gradient of the curve y = 2x3 - 5x2 + 46x + 87 at the point where it crosses the x-axix.
2. Show by differentiation and solving a quadratic equation, that there are no points on the above curve where the gradient is zero.
dy/dx = 6x2 - 10x + 46
It crossess at x-axis where y = 0 ( it it right...?) I then calculate the roots of the equation, and the two roots of x are the points where it crossess the x-axis.
How do I do the part 2 problem...?
You have found the derivative of the function, so how about setting it equal to zero. If you then solve it, you will find all the x values where the derivative is zero (if they exist). What should you expect if no zero derivatives exist?
what do you mean by "What should you expect if no zero derivatives exist?" What do I do?
My question for the problem is are both part1 and part 2 the same thing. I mean part 1 says calculate and part 2 says show by differentiation and solving a quadratic equation. Do I have to differentiate(for part 2) one more time..?
The question asks you to show that the gradient of y = 2x3 - 5x2 + 46x + 87 is never zero. You have already found the derivative of the function, dy/dx = 6x2 - 10x + 46, which is the first step.
You have been asked to show that there exists no x such that the gradient is zero i.e. there are no such x values that make dy/dx = 0, or 6x2 - 10x + 46 = 0. So your task then becomes to show that no real x values satisfy the equation 6x2 - 10x + 46 = 0 i.e. the equation has no solutions. How can you show it has no real solutions?
solving the quadratic equation i get x = (5+18.5i) and (5-18.5i) which are the complex roots and does this mean that it will never touch the x-axis...?
Right. By showing that the equation has only non-real solutions, you have shown that there exists no real value of x that makes dy/dx equal zero i.e. the curve never has a zero gradient.
  • · Replies 27 ·
