Question-can a neutron star shed mass?
The discussion centers around the mechanisms by which a neutron star can shed mass after its formation from the collapse of a stellar core. It explores theoretical aspects related to neutrino emissions, thermal photon cooling, and other processes that may contribute to mass loss.
  • Some participants propose that a neutron star can shed mass through neutrino emission when it is at high temperatures, with significant heat loss translating to mass loss.
  • Others mention that at lower temperatures, thermal photon cooling occurs, which also contributes to mass loss, with power proportional to T4.
  • A participant introduces the idea that an electron interacting with a nucleus can emit a neutrino-antineutrino pair instead of a single photon, leading to a different cooling process with power proportional to T6.
  • There is a discussion about the "new" state of a neutron star, with some clarifying that this refers to the protoneutron star phase, during which deleptonization occurs, resulting in neutrino loss.
  • Further elaboration indicates that neutrino emissions can dominate for a significant duration, extending beyond the protoneutron star stage, influenced by the superfluidity of degenerate matter.
Participants generally agree that mass loss can occur through various mechanisms, particularly involving neutrino emissions. However, there are nuances regarding the definitions of the "new" state and the processes involved, indicating some level of disagreement or lack of consensus on specific details.
There are limitations in the discussion regarding the assumptions made about the conditions under which mass loss occurs, the definitions of terms like "new" and "protoneutron star," and the complexity of the processes involved, which remain unresolved.
Duane M
Question--can a neutron star shed mass?
Once the steller core of a massive star collapses into a neutron star, is there any known mechanism by which the neutron star can shed mass?
Astronomy news on Phys.org
Yes. When a neutron star is "new" with temperatures above ~ 109 K, there is strong heat-loss (therefore mass) by neutrino emission. At lower temperatures, there is "standard thermal photon cooling", which has a power proportional to T4 K. Another process is where an electron passes by a nucleus and, instead of emitting a single photon emits a neutrino-antineutrino pair. This has a power of about T6.
Either way, the heat loss translates to mass loss by emission of various particle types. There are more complicated processes which involve interaction of the (huge) magnetic field, but the bottom line is that any heat loss will also lead to a mass loss.
Yes. When a neutron star is "new"...
By "new" I think that you mean when is exactly what is called a protoneutron star. Then yes, it loses all its neutrinos by a process called deleptonization
Even after the protoneutron star (PNS) stage, neutrino emissions dominate for ~100 years in the "standard" model and as much as 1 million years in certain cases depending on the state of the "superfluidity" of the degenerate matter.
100 to 1 million years certainly extends well beyond the PNS stage. Deleptonization is a description of the change in properties of the matter in a neutron star, neutron loss is called neutron diffusion. See at least pages 1-4 (out of 61) at:
http://arxiv.org/PS_cache/astro-ph/pdf/0012/0012136.pdf
  • · Replies 48 ·
  • · Replies 0 ·
  • · Replies 28 ·
