| Thread Closed |
Mass in relativity |
Share Thread | Thread Tools |
| Jan29-09, 10:35 AM | #1 |
Mass in relativity
Dalespam posted in another thread (as have others in other threads) responding to a comment:
In SIX EASY PIECES for example (copyright 1997) pages 87 to 91 Richard Feynman seems to say repeatedly mass DOES increase with speed. For example: |
| Jan29-09, 11:27 AM | #2 |
Rest mass + energy needed for relativistic speed = relativistic mass.
Relativistic mass is only observed from outside the inertial frame. All non accelerating frames are at rest so maybe relativistic mass is an illusion. Next - Someone that knows what they are talking about. |
| Jan29-09, 12:15 PM | #3 |
I refer the honourable gentleman to the answer I gave a few threads ago:
| Jan29-09, 01:10 PM | #4 |
| Jan29-09, 01:16 PM | #5 |
DrGreg...thanks for your input...I DID see that earlier post and forgot about it.....if that's the convention generally used, that's just peachy by me...(If you just tell me the same thing a few more times I might even remember it!!)
Until I was just rereading Feynmann's book this morning I had also forgotten how blatently he describes KE and relativistic mass being "one"....when he says because the resulting object of a collision is heavier due to energy content, "it will be a different object" lights went off.... His writing is just great!!! |
| Jan29-09, 01:25 PM | #6 |
So let's say we have two isolated particles and an arbitrary reference frame (I don't see how in this case you could define an Inertial Reference Frame). Can you write equations of motion?
| Jan29-09, 01:31 PM | #7 |
Mentor
| Jan29-09, 01:59 PM | #8 |
All non accelerating frames are at rest so maybe relativistic mass is an illusion." DrGreg said "...but many users in this forum insist on following the modern convention of referring to invariant mass a.k.a. rest mass. It's the one I prefer myself,..." I am in no way in DrGreq's league but it sounds like we are saying something similar. It seems that maybe KE should be ignored (until impact) unless there is an ether to compare speed to. |
| Jan29-09, 03:56 PM | #9 |
Mentor
The reason the modern convention is used is because of the four-momentum. Relativistic mass is the timelike component of the four-momentum, which is also (and more commonly) known as energy. Invariant mass is the norm of the four momentum, which does not have another common name. So just from a communication standpoint it makes more sense to use the word "mass" to refer to the norm and "energy" to refer to the timelike component. Secondly, even though laypeople and pop-science books tend to use relativistic mass it is a source of confusion. Mass is generally thought to be a property of an object rather than an observer, so the idea that motion increases mass leads to a feeling that motion is still absolute. Also, since mass is usually thought to be a property of an object it does not make sense that it could have multiple different values at the same time as relativistic mass does. IMO (and in the opinion of the modern physics community) there is no reason to use "relativistic mass" instead of energy. E.g. "An object cannot accelerate to the speed of light because it would have infinite energy" works just as well as "An object cannot accelerate to the speed of light because it would have infinite (relativistic) mass" However, in the end it is just a convention, as is the use of any word. |
| Jan29-09, 03:58 PM | #10 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mass in relativity
| Mass in Relativity | Special & General Relativity | 23 | ||
| mass in relativity | Special & General Relativity | 5 | ||
| mass spectometer and relativity | Introductory Physics Homework | 7 | ||
| The concept of mass in relativity | Special & General Relativity | 6 | ||
| Relativity of Mass or 'Weight' ? | Special & General Relativity | 6 | ||
