Finding Electric Field using Gauss's Law for a Solid Ball with Charge Density
  • Thread starter Thread starter Seraph404
    Gauss's law Law
The discussion revolves around finding the electric field inside a solid ball with a uniform charge density using Gauss's Law. The original poster seeks to determine the electric field at a distance less than the radius of the ball and is attempting to express the result in terms of the charge density, radius, and permittivity of free space.
  • Participants discuss the application of Gauss's Law and the implications of the charge distribution. The original poster expresses confusion regarding the dependence of their answer on the radius of the ball and seeks clarification on the flux through the surface of a sphere. Others provide hints and encourage checking assumptions about the electric field's uniformity within the sphere.
The discussion is ongoing, with participants providing hints and exploring different interpretations of the problem. Some have offered guidance on the correct application of Gauss's Law, while others have shared their own calculations and reasoning. There is a recognition of the need for conceptual understanding, particularly regarding the role of the radius in the electric field expression.
Participants note challenges with the material and express frustration with the instructional methods encountered in their course. There is an acknowledgment of the importance of deriving concepts rather than relying solely on equations.
Seraph404
We have solid ball of radius rb and charge density [tex]\rho[/tex].
I need to find the magnitude of electric field E(r) at a distance r < rb from the center of the ball and express my answer in terms of [tex]\rho[/tex], r, rb, and [tex]\epsilon[/tex] 0.
Gauss's Law
[tex]\int[/tex] EA = Q/[tex]\epsilon[/tex]0
E*(4*[tex]\pi[/tex]*rb2) = 4*[tex]\pi[/tex]*r3*[tex]\rho[/tex]/(3*[tex]\epsilon[/tex]0)
E(r)= (r3*[tex]\rho[/tex])/(3*rb2*[tex]\epsilon[/tex]0)
But the website I check my answers with tells me it's wrong. Can someone help me to understand, please? The hint it gave me was that my answer should not depend on rb. Why wouldn't it?
This looks right on first glance.
The integral on the left should yield
E*(area enclosed by a sphere) = E*(4*pi*r_b^2) .
The right hand side is simply, the charge density times the volume of the arbitrary sphere whose r < r_b.
Q = (4/3 pi r^3) * rho.
Therefore the resulting ratio should go as
E(r < r_b) = r^3 * rho /(3 * r_b^2 *epsilon).
Check with the instructor. The computer's solution may have a typo.
Hi Seraph404! :smile:
(have a pi: π and a rho: ρ :wink:)
Hint: E is the same for all points on the sphere of radius r < rb
so what is the flux through the surface of that sphere?
Ah.. ><
I'm almost 99% sure that the problem is me. But I'll ask anyway if nobody else on here can spot the mistake.
Um. I guess radially outward? But how does that remove my need for rb in the expression?
I should also have mentioned that I'm struggling with the material. My professor is absolutely no help. I've started skipping lecture just to hang out in the Physics helpdesk and work problems, since that's the only way I'm going to learn any of this.
Ok, I did the math on paper instead of in my head.
Here is the answer. Got a pen and paper? Nope that pen is dry. Try another one.
Ahh one that works.
Left hand side = E * (area of a sphere ENCLOSING THE CHARGE)
= E * (4*pi*r^2)
Right hand side = Q/epsilon
= (volume of ENCLOSED CHARGE) * (Charge density)
= (4/3) * pi * r^3 * rho / epsilon
Result => E = (r * rho) / (3 * epsilon)
You can check this at the boundary where r = r_b. Let me show you.
Hi Mr.Amin! Welcome to PF! :smile:
But please help by giving just hints on this forum, rather than by actually doing. :wink:
Yes, but how much is it? E(r) times what?
And then what should that flux be equal to?
(what is flux through a surface always equal to? :wink:)
The continues from my previous post, I can't type as fast as you!
r > r_b
Left hand side = E * (4 * pi * r^2)
Right hand side = (4/3) * pi * r^2 * rho / epsilon
Solve for E
E = (r^3 * rho) / (3 * epsilon * r^2)
= (r * rho) / (3 * epsilon).
You could have gotten here if you used E = 1/(4*pi*epsilon) * Q/r^2 .
Now check E(r = r_b) for both equations.
for r < r_b
E(r = r_b) = (r_b * rho) / (3 * epsilon)
for r > r_b
E(r = r_b) = (r_b * rho) / (3 * epsilon).
The reason why r_b does not come into your previous question is because a uniform distribution of charge creates essentially no net electric field. If you pretend your sensor has penetrated into the charged sphere, everything at the radius above it will add to zero field. ONLY the charge in the sphere below the probed radius will generate the non-zero electric field.
This works for gravity too since Gauss's law works for g-fields as well.
Oh.. I guess I didn't realize that the area in Gauss's law was for enclosed charge only. Anyway,Thanks guys! I will definitely refer back to this post when I work future problems! Hopefully, the more of these I work, the better my understanding of this subject will be.
My main problem is that our prof began by throwing equations at us (not even bothering to derive them) and scribbling down example problems here and there that hardly any of us could make out. So conceptually, I have little to no idea what is going on in this subject. The book is a big help, but sometimes I need things drawn out for me before I'll really understand. Anyway, thanks again!
  • · Replies 26 ·
