Electric field of half a spherical shell
The discussion focuses on calculating the electric field of a half spherical shell using Gauss's law. A user expresses difficulty in identifying an appropriate Gaussian surface for the problem. Another participant suggests an alternative approach by considering the symmetry of the system and integrating the contributions to the electric field from small segments of the circular intersection in the (x, y) plane, parametrized by angle φ. This method emphasizes the importance of symmetry in simplifying the calculations.
  • Understanding of Gauss's law in electrostatics
  • Familiarity with electric field concepts and calculations
  • Knowledge of integration techniques in calculus
  • Ability to visualize three-dimensional geometric shapes and their projections
  • Study the application of Gauss's law to various symmetrical charge distributions
  • Learn about electric field calculations for spherical and cylindrical geometries
  • Explore integration techniques for calculating fields from continuous charge distributions
  • Investigate the role of symmetry in simplifying electrostatic problems
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone seeking to deepen their understanding of electric fields and Gauss's law applications.
asi123
Hey guys.
I've been trying to solve this question using Gauss law but I can't think of a surface that can contain this thing.
Is there another way to solve this?
Thanks a lot.
Maybe it helps to draw a picture... suppose that the symmetry axis is the z-axis. Consider an intersection in the (x, y) plane, i.e. a circle of radius r(z) at height z. Draw some electric field lines to a point on the z-axis... the symmetry will provide some cancellations. If you use an angle [itex]\phi[/itex] to parametrize the circle, then you can divide the circle into small segments of length [itex]r(z) \, d\phi[/itex] and write down the contribution to the E-field from each segment. Once you have that, all you have to do is sum (i.e. integrate) over phi.
Yes I know, it's a lot of work :sad:
  • · Replies 17 ·
