Need help locating high power shunt resistor
The discussion revolves around locating a high power shunt resistor suitable for handling 20-25 W with a resistance of less than 1 ohm. Participants explore options for sourcing such components and share personal experiences related to shunt resistors.
  • One participant seeks recommendations for a shunt resistor that can handle 20-25 W and is under 1 ohm.
  • Another participant asks for the maximum current expected to be handled by the shunt resistor.
  • A suggestion is made to check eBay for affordable options, with one participant sharing their experience of purchasing a shunt that handles 200 amps at 0.75 ohms.
  • One participant speculates that the expected current might be a couple of amps and questions if a specific product from Ohmite would be suitable.
  • A suggestion is made to consider Vishay, which offers a wide variety of resistors that may meet the requirements.
  • A participant shares a personal anecdote about using a shunt resistor for current limit sensing in a DC motor application, detailing the specifications and the context of its use.
Participants have not reached a consensus on the best source or specific model of shunt resistor, and multiple suggestions and experiences are presented without resolution.
Some participants' responses depend on specific current ratings and resistance values, which may not align with the original request. There is also variability in the context of use for shunt resistors, which may affect recommendations.
Individuals seeking high power shunt resistors for applications in electrical engineering, particularly those involved in current sensing or motor control, may find this discussion relevant.
atlbraves49
I need to find a shunt resistor (basically a low resistance resistor), that can handle 20-25 W, and is less than 1ohm resistance. Not really sure how to find some.. can anyone give suggestions?
What is the maximum current you expect to handle?
Check ebay. I got one that handles 200 amps and has 0.75 ohms very cheaply.
the current i think is at most a couple Amps?
would something like this work?
http://www.ohmite.com/cgi-bin/showpage.cgi?product=tch_series
Vishay has a huge variety. I am sure they have something to fit your needs.
http://www.vishay.com/resistors-discrete/
Holy smokes! What were you using it for? Current limit sensing on a giant power supply?
Heh, I knew you'd ask :smile: Well, it was for a DC motor pumping dozens of hydraulic lifts in a truck trailer capable of carrying automobiles. The idea was not to exceed the motor's maximum current rating, when the trailer was subjected to heavy loads. The motor was expensive and has blown before. If I remember correctly the peak current reached about 120 amps @ 24 volts. I should say, the shunts resistance was 75 milliohms, not 0.75 ohms.
But later on, they changed their trailer, dismantled the shunt and gave it back to me. So right now it's sitting in my junk box. I pet it sometimes :smile:
  • · Replies 20 ·
  • · Replies 19 ·
