Thread Closed
Derivation of equation for sliding object
Share Thread Thread Tools
Jan30-09, 02:04 PM   #1
1. The problem:
Derive an expression in its simplest form to show the relationship between the mass, ramp angle, and acceleration of the sliding object. Explain clearly but briefly the effect of each term in the expression on the actual acceleration, as the ramp angle changes.
No known variables. Context of this question: part of a lab, in which we found values of friction and coefficients of friction through measuring acceleration of objects sliding down a ramp.
2. Relevant equations
a=Fnet/m
Fgramp=mgsin(x)
Ffk=ukmgcos(x)
3. The attempt at a solution
a=Fnet/m
a=(Fgramp-Fk)/(m)
a=(mgsin(x)-ukmgcos(x))/(m)
a=gsin(x)-ukgcos(x)
a=g(sin(x)-ukcos(x))
Is this the right equation? If so, mass has no effect on the acceleration. Acceleration increases as angle increases.
However, my teacher told me that the equation is supposed to look like:
a=_________+_________
I suppose it is possible the 2nd term is negative... but I am not sure.
Are there different equations? We also calculated ideal and measured accelerations to find the value of friction. Is this any use?
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan30-09, 03:05 PM   #2
Looks like you've got it right.
[tex]a=g(sin\theta-\mu cos\theta)[/tex] where [tex]\theta[/tex] is the angle between the ramp and the horizontal. Note that [tex]a[/tex] is the acceleration when the object has been released and slides down the ramp. If the object has been pushed up the ramp and is in the process of sliding up then a slightly different equation governs its acceleration.
Thread Closed
Thread Tools
Similar Threads for: Derivation of equation for sliding object
Thread Forum Replies
magnitude of force on a sliding object- help pleaaase! Introductory Physics Homework 3
Derivation of an S.H.M. Equation Introductory Physics Homework 2
Kinetic energy of an object sliding down a sphere Advanced Physics Homework 2
Derivation of Momentum Equation (Eulers Equation) Differential Equations 0
Stuck on sliding object problem Introductory Physics Homework 6
