Shapiro Effect and Gravitational Lensing
The discussion centers around the Shapiro Effect and its implications for gravitational lensing and cosmological redshift. Participants explore various interpretations of these concepts, questioning established theories and proposing alternative explanations.
  • One participant expresses skepticism about the Big Bang Theory (BBT) and the Doppler effect, seeking alternative explanations for cosmological phenomena, particularly regarding the Shapiro Effect and gravitational lensing.
  • Another participant acknowledges that a remote observer would measure a modification of the speed of light due to gravitational potential but questions whether this leads to a redshift, suggesting the need for calculations based on Schwarzschild spacetime.
  • Concerns are raised about the mathematical rigor of the gravitational lensing ideas presented on the referenced webpage, with a suggestion that there should be observable distortions like smudging or arcing.
  • Some participants clarify that while light travels at speed 'c' locally, distant measurements may indicate a different effective speed due to gravitational effects.
  • There is a discussion about the implications of using 'c' as a local reference frame and the challenges posed by singularities in current models.
Participants express differing views on the implications of the Shapiro Effect and gravitational lensing, with no consensus reached on the interpretations or calculations involved. Some participants agree on the local constancy of the speed of light, while others challenge this notion in the context of gravitational effects.
There are unresolved assumptions regarding the mathematical treatment of gravitational redshift and the Shapiro Effect, particularly in relation to Schwarzschild spacetime. Participants also highlight the limitations of the referenced webpage's explanations.
shrumeo
I have been searching for alternatives to BBT and the doppler effect to explain everything, and have been dissapointed to find a lot of crackpots out there. I have recently found this website:
http://www.geocities.com/newastronomy/Index.htm
and the thing makes all kinds of sense (to my limited intellect)
But, there are a few problems I have with the explanation of "extra" gravity from stars and the explanation of neutron stars.
Are there any real physicists out there that are willing to debunk these ideas?
I've seen physicists "ruling out" the Shapiro Effect for redshifts on their websites, but their explanations were always "over my head". Can anyone do it in semi-plain english??
Also, what about his ideas about gravitational lensing ? I think it's pretty cool and makes a little too much sense. Am I blind?? :confused:
Astronomy news on Phys.org
I have not read the whole webpage, but only the part describing the hypothesis of cosmological redshift due to the Shapiro effect.
As far as I know, a remote observer would indeed measure a modification of the speed of light when light passes through a gravitational potential, since it experiences a time-delay wrt to a trayectory through empty space.
But I am not sure that this will produce a redshift. To calculate the redshift due to gravitation one has to make use of the formula for gravitational redshift derived from a Schwarzschild spacetime. This will lead to a prediction of redshift as well as blueshift when light falls into and comes out from potentials.
May be I am missing something.
Regards.
i think the gravitational lensing ideas on this webpage havent' been totally thought out, mathwise especially.
wouldn't there be at least a little distortion? smudging, arcing, that type of thing?
and OH! I guess I didn't read carefully. The shapiro effect is on the SPEED of the light? hmm, i guess I was under the assumption that light in a vacuum has ONE speed, period. I thought it reduced the energy! here i was thinking everyone thinking doppler effect and expanding space were retarded.
I think this webpage is just some bozo like me, who doesn't do this for a living, but tries to wrestle with the concepts without doing any of the math.
shrumeo said:
The shapiro effect is on the SPEED of the light? hmm, i guess I was under the assumption that light in a vacuum has ONE speed...
Yes, locally always c, but seen from far away (wrt a potential) one will measure a differend speed as c.
Regards.
again, i thought that light in a vacuum went c
in ALL inertial reference frames and wrt any other reference frame
if you use 'c' as the local reference frame, it solves every objection to what is observed. this is not an arbitrary measure. as a predictive model, it has flaws. the singularity at the beginning of time breaks down the math of all currently known models.
This is true in a globally flat spacetime, but I think a Schwarzschild spacetime is usually assumed in order to calculate the gravitational redshift and the Shapiro effect. In a Schwarzschild spacetime there is a dependence of the speed of light with the gravitational potential when measured by distant observers (but not when measured in a local experiment). Regards.
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 18 ·
