What is the result of combining vectors A and B?
  • Thread starter Thread starter queenspublic
The discussion revolves around combining two vectors, A and B, with specified magnitudes and directions. Vector A is directed east with a magnitude of 2.00 m, while Vector B has a magnitude of 6.00 m and is directed 24.0° west of north. Participants are exploring how to determine the resultant vector's magnitude and direction, as well as the difference between the two vectors.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss breaking the vectors into their x and y components to perform vector addition and subtraction. There are questions about the use of sine and cosine functions for this purpose, and some participants suggest drawing the vectors to visualize the components.
There is an active exchange of ideas regarding the breakdown of vectors into components. Some participants have provided guidance on how to approach the problem, including the use of trigonometric functions and the Pythagorean theorem for determining magnitude and direction. Multiple interpretations of the vector operations are being explored.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the component breakdown and the operations that can be performed on those components.
queenspublic
Vector A has a magnitude of 2.00 m and is directed east. Vector B has a magnitude of 6.00 m and is directed 24.0° west of north.
(1) What is the magnitude of A + B?
(2) What is the direction of A + B?
(3) What is the magnitude of B - A?
(4) What is the direction of B - A?
Break the vectors into their <x,y> components and then do the indicated operations.
How do I break it? Do I use sine and cosine?
Add two vectors. Find the x and y components of the two vectors. Add the x components to get the net x component. Do the same for the y components. Draw the net x component and the net y component. Magnitude is determined with the Pythagorean theorem, and angle is determined with an inverse tangent. If, instead, you add the vectors on a vector-capable calculator, all angles must be relative to the positive direction of the x axis.
Yup. your first vector is already in component form because it is just pointed east, so its of the form <2,0>. (remember sign of the number matters in this).
For your second one if you draw it out you'll notice you have a triangle. Use your sin and cos functions to find the X and Y components of the second vector.
Then you'll have vector A broken into x and y =<x1,y1> and vector B broken into x and y <x2,y2> and then you can do the operations to them. Remember when you are doing the operations you can only add x to x and y to y.
<1,1>+<2,5> = <3,6>
[EDIT] and yes, about the angle with respect to the origin it brought up inverse tangent. That is because tan=(opp/adj)... which is pretty much the same thing in this case as tan(theta)=(y/x) so the angle w.r.t the positive x-axis is theta=arctan(Y/X)
  • · Replies 16 ·
