Finding the Optimal Mass for a Pressure Cooker Cover
  • Thread starter Thread starter derekjn
    cooker Pressure
The discussion revolves around determining the optimal mass for a pressure cooker cover to achieve a cooking temperature of 120°C. The problem involves understanding the relationship between pressure, force, and area in the context of a sealed cooking environment.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the equation relating pressure, force, and area, with attempts to calculate the necessary mass for the cooker cover. Questions arise regarding the inclusion of atmospheric pressure in the calculations and the accuracy of the initial attempts.
There is ongoing exploration of the calculations involved, with some participants providing their calculations while others question the assumptions made, particularly regarding atmospheric pressure. The discussion reflects a mix of interpretations and attempts to clarify the problem without reaching a consensus.
Participants note the importance of considering both the saturated vapor pressure and the atmospheric pressure in their calculations. There is also mention of specific values and equations relevant to the problem, indicating a focus on the mathematical aspects of the scenario.
derekjn
A pressure cooker is a sealed pot designed to cook food with the steam produced by boiling water somewhat above 100 C. Consider a pressure cooker with a weight of mass m covering the only hole (which has a diameter d = 0.003 m) on top of it. What should m be in order to cook food at 120 C. Assume the atmospheric pressure outside the cooker is 1 atm.
Pressure = Force/Area
Saturated vapor pressure of water at 120 C = 1.99 x 10^5 Pa
Since P = F/A, F = AP. F must then at least equal the weight mg of the weight at the top of the pressure cooker in order to lift it and let steam escape. So m = AP/g. The result I get from this approach is incorrect. Any help would be greatly appreciated.
Will you please show your calculation?
PA = mg
m = PA/g
where P is the pressure inside the cooker, A is the area of the hole, and m is the mass of the weight.
[tex]m = \frac{(1.99)(10^{5})(\pi)(0.003^{2})}{(9.8)} = 0.574 kg[/tex]
Have you taken into account the atmospheric pressure?
Yes, I tried to include the difference in pressures (199,000 Pa - 101,300 Pa) as P in the equation, but still came up with an incorrect answer.
Area = pi*d^2/4
16K
28K
