Kinetics Question (spent over 7 hours on this)
  • Thread starter Thread starter bengalkitties
    Kinetics
The discussion revolves around a kinetics problem involving the reaction AB → A + B. Participants are analyzing a plot of 1/[AB] versus time, which yields a straight line with a specific slope, and are tasked with determining the concentrations of products A and B after a given time based on initial conditions.
  • Participants discuss the use of the integrated rate law for second-order reactions and question the linearity of the plot. There is confusion regarding the order of the reaction and the implications of the slope's units. Some participants express frustration over incorrect attempts at solving the problem.
The discussion is ongoing, with participants exploring different interpretations of the reaction order and the implications for the calculations. Some guidance has been offered regarding the correct application of the rate laws and conservation of mass, but no consensus has been reached on the correct approach to the problem.
Participants note potential errors in the problem statement and discuss the implications of the reaction being second order. There is mention of the initial concentration of AB and the need to account for the conversion to products, which adds complexity to the calculations.
bengalkitties
The following reaction was monitored as a function of time:
AB---> A + B
A plot of 1/[AB] versus time yields a straight line with slope 5.2×10−2 M \s.
If the initial concentration of AB} is 0.210 M, and the reaction mixture initially contains no products, what are the concentrations of {A} and {B} after 80 s?
1/A = kt + 1 / A initial
1/A = (5.2x10^-2)(80 s) + 1/0.21 M
*When I did this equation it was wrong. The correct answer was that the concentration of both A and B=9.8×10−2,9.8×10−2. Please tell me what I am doing wrong. Thanks!
[tex]k=\frac{rate}{[AB]}[/tex]
and [AB] at t=0 can be used because k is a constant ratio. The rate is the slope of the line. However, the problem appears to have an error:
[tex]\frac{1/[AB]}{t}=5.2x10^{-2}M/s[/tex]
The units should be
[tex]\frac{1}{Ms}[/tex]
If 1/[AB] vs. time is linear then k is not linear. Is this a first order reaction?
Thanks for your response. I think the rate is second order because given was: Rate=k,[AB]^2
I just plugged in those numbers for first order and I am still getting the answer wrong. This question is frustrating me to the max. Any help would be hugely appreciated.
Since it's a second order reaction, your equation for 1/[AB] is correct. Use conservation of mass. Your answer gives the concentration of AB after 80 seconds so this means what was converted is
.21 - [AB] = 9.8 x 10-2 M = concentration of products.
