Notion of the infinitesimal analysis in R^n
  • Context: Graduate
  • Thread starter Thread starter samspotting
    Analysis Infinitesimal
The discussion revolves around the concept of infinitesimals in the context of calculus and analysis in R^n. Participants explore the differences between traditional epsilon-delta formulations and the use of infinitesimals, including their rigor and applicability in various mathematical and physical contexts.
  • Some participants note that the notion of infinitesimals is emphasized in lower calculus courses but is largely absent in more theoretical analysis, which relies on epsilon-delta proofs.
  • Others argue that the epsilon-delta approach was developed due to the challenges in rigorously defining infinitesimals, with some suggesting that non-standard analysis provides a rigorous framework for their use.
  • A participant mentions that while infinitesimals can be useful as shortcuts for limits, they can also lead to confusion and misconceptions if not properly understood.
  • Some contributions highlight that standard mathematical techniques can also incorporate infinitesimals through concepts like big-Oh notation and dual numbers.
  • One participant expresses concern that teaching calculus without epsilon-delta limits may leave students with misunderstandings about mathematical concepts, such as the equality of 0.999... and 1.
  • Another participant challenges a specific mathematical presentation regarding the inversion of a matrix representing an infinitesimal, indicating that it does not exist.
Participants express a range of views on the utility and rigor of infinitesimals versus epsilon-delta formulations. There is no consensus on the superiority of one approach over the other, and the discussion remains unresolved regarding the best pedagogical methods for teaching these concepts.
Some participants note that the use of infinitesimals can lead to technical issues and that their application may depend on specific definitions and contexts. The discussion reflects a variety of perspectives on the foundational aspects of calculus and analysis.
samspotting
When I was in calculus, the notion of the infinitesimal, the smallest possible unit, was really emphasized.
When I switched into a more theoretical section of calculus (analysis in R^n), nothing about infinitesimals is said, instead all the proofs are in the style of epsilons and deltas.
Is the infinitesimal just a broad statement about something like for all epsilon strictly greater than zero this must work?
The infinitesimal in lower calculus courses is just a way of pushing rigorous limits and limiting behavior under the carpet so that they can deal with just the results of analysis instead of worrying about proving some rather delicate/subtle concepts. However, there is a formulation of analysis that uses the concept of infinitesimal rigorously, this is usually referred to as non-standard analysis.
Yeah, the epsilon/delta approach was created because infinitesimals weren't rigorous enough. However, you can still read about them in Keisler's book.
I would rather say that it was because infinitesimals are too difficult to make rigorous. Less well known than non-standard analysis which appeared in the 1960s is the more recent analysis in smooth worlds:
http://en.wikipedia.org/wiki/Smooth_infinitesimal_analysis
From a mathematicians viewpoint, using infinitesimals to do calculus is like using a howitzer to defeat a bear. They would much rather show that it is possible to defeat the bear with a simple knife i.e. for the development of calculus it will suffice to speak of only real numbers e.g. epsilon-delta formulation.
In intermediate/advanced level physics infinitesimals are used all the time in place of time consuming repetitive arguments dealing with limits.
Infinitessimals of the type in non-standard analysis (NSA) are very tricky. They only really work under two circumstances:
1. You pay close attention to the technical details governing their use
2. You avoid doing anything creative, and only regurgitate arguments you've been told are valid
The emphasis in an elementary calculus class is how to make effective calculations, and is completely independent of the theoretical foundation. NSA doesn't change how you integrate by parts. Infinitessimals aren't used when you need to estimate how much error you introduce by using [itex]\sqrt{101} \approx \sqrt{100}[/itex]. Infinitessimals aren't used when figuring out how many terms of a Taylor series you need to compute [itex]\sin 1[/itex] to 3 decimal places.
Furthermore, even for the theoretical foundations, the elementary calculus student won't see a practical difference using infintiessimals over epsilon-deltas; e.g. in proving a particular limit formula, you're usually going to do pretty much exactly the same work with inequalities whether you're using epsilon-deltas or you're using infinitessimals.
And people seem to forget that standard techniques do offer infinitessimals -- big-Oh notation, dual numbers, tangent spaces, ...
Generally speaking, (I believe) physicists' usage of infinitessimals fall into two categories:
1. Arguments that pretty much directly translate into perfectly rigorous arguments
2. Arguments that brush away dangerous technical issues
(An example of the latter is thinking of the Dirac delta as being zero everywhere except at the origin, which makes it somewhat difficult to fathom just how badly behaved ideas like [itex]\delta(0)[/itex] or [itex]\delta(x) \delta(x)[/itex] really are)
(For the record, I really do like NSA)
I think teaching calculus without using epsilon-delta limits is silly. Infinitesimals are more difficult to make rigorous, and are therefore more confusing. Students will be left thinking you are doing voodoo rather than legitimate math. They will also be left with silly notions such that "0.999... != 1", etc., thinking that such expressions can "differ by an infinitesimal".
However, once you understand them as a shortcut for limits, infinitesimals are useful. Essentially, we can define an infinitesimal epsilon as some number such that
[tex]\epsilon \neq 0[/tex]
and
[tex]\epsilon^2 = 0[/tex]
This sounds like nonsense if epsilon is taken to be a real number. However, one may consistently define epsilon as a matrix, such as
[tex]\epsilon = \left( \begin{matrix} 0 & 1 \\ 0 & 0 \end{matrix} \right)[/tex]
Then an ordinary real number would be a diagonal matrix. Sums would work out as expected:
[tex]1 + \epsilon = \left( \begin{matrix} 1 & 0 \\ 0 & 1 \end{matrix} \right) + \left( \begin{matrix} 0 & 1 \\ 0 & 0 \end{matrix} \right) = \left( \begin{matrix} 1 & 1 \\ 0 & 1 \end{matrix} \right)[/tex]
[tex](1 + \epsilon)^2 = 1 + 2\epsilon + \epsilon^2 = 1 + 2\epsilon[/tex]
[tex]\left( \begin{matrix} 1 & 1 \\ 0 & 1 \end{matrix} \right) \left( \begin{matrix} 1 & 1 \\ 0 & 1 \end{matrix} \right) = \left( \begin{matrix} 1 & 2 \\ 0 & 1 \end{matrix} \right) = \left( \begin{matrix} 1 & 0 \\ 0 & 1 \end{matrix} \right) + 2 \left( \begin{matrix} 0 & 1 \\ 0 & 0 \end{matrix} \right)[/tex]
Then, we can define the derivative as
[tex]f'(x) = \frac{f(x + \epsilon) - f(x)}{\epsilon}[/tex]
However, actually evaluating such derivatives (without using limits) requires us to already know about Taylor series, if our function is something more complicated such as [itex]\sin x[/itex].
That presentation is not 100% right, because
[tex] \frac{1}{\epsilon} = \left(\begin{array}{cc}<br /> 0 & 1 \\<br /> 0 & 0 \\<br /> \end{array}\right)^{-1}[/tex]
does not exist.
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 48 ·
